Kenevo SL Official 2022 Kenevo SL (KSL) Megathread!
Doomanic
🛠️Wrecker🛠️
8,947
10,890
It was a joke, as evidenced by the laughing emoji at the end of the sentence.
CallumBolch
Geelong, Australia
Hi all.
New KSL owner here. Picked up a Comp 22 model cheap last week after riding a KenLevo (Cascade LSK) for the past 18 months. Wanting a second eMTB and a park bike and thought a well priced Kenevo SL would tick both boxes.
Photo below is its current state and how it'll have to stay after breaking my arm riding 2 weeks ago (x-ray attached because it's gnarly).
Current and future plans:
- mullet
- 230x65mm shock (remove Float X spacer) and it'll get my EXT Storia coil off my KenLevo for bike park. Should get 177mm or so travel with that. Same mounting hardware ftw.
- 180mm 38mm fork. Currently keeping an eye on secondhand stuff.
- shorter cranks - anyone got a good lead on 155-160mm cranks for the SL 1.1?
- Lewis LHT Ultimate or LHP U4 brakes so both bikes share common pads and spares.
- rigid seat post. What you see here is what's gonna stay for bike park days. Cutting the post down and slamming it for park. Dropper back in for regular riding.
Anyone else running a similar set-up and have insights?
nB2000
84
33
South coast UK
KSL is a lovely bike especially with a Storia. (And a Zeb) You’ll need the short remote reservoir as the std one hits the frame in the hoop.
275 rear works great. Turns in better in tight terrain. Stringer wheel. More mud clearance. 338BB height with head mid (about 64deg) and chainstays in high BB position.
45 stem cuts the XL nicely. I needed a 50 rise Burgtec bar as the headtube’s relatively short.
Michelin DH 22 front DH16 rear.
160 crank works well
Specialized M30 praxis Crank 160mm bestbike.de
Praxis Works LEVO SL CRANKSET ALU MODEL 20/21/22 SL SYSTEM, M30, 160MM R+L ARM - LEVO SL CRANKSET ALU MODEL 20/21/22 SL
€58.78 EUR
Postage and packaging€12.56 EUR
VAT€14.27 EUR
Total€85.61 EUR
SonOfBovril
7
South Africa
I’m running an S5 with 180mm Zeb and 165mm Alu praxis cranks.
You might find it very slack with 180mm up front and the mullet rear wheel, depending on how steep the trails are in your area? I had to run the headset in the steeper setting to keep the wheel from flopping, but the areas I ride are relatively flat…
nB2000
84
33
South coast UK
180 is ok I think with 275 rear. Head mid. . Sags more. Mines a 180. BB at my target 338mm static.
I’m used to flop as I got the Geometron bug in 2015. Once over walking speed I like it. I rarely get chance to ride proper steep.
panther-ra
7
8
Oslo
Hi there! I've a couple of question about KSL1.
1. I have KSL gen 1 with master mind TCU - can I integrate sram AXS as a sensor?
2. If I'm going to change the geometry via bottom flipchip - it will reduce the required length of the chain. How do you setup your bike, if you need 2 different geometries?
3. Does this frame compatible with spring rear shock?
4. How often do I need to open motor and change the lube in it? Is it possible to do without workshop?
alleeex
58
173
Wales, UK
1. Yes you can connect the derailleur to the TCU so you can see (e.g) what gear you’re in or the battery level, but I’ve found that this drains the AXS battery very quickly.
2. I’ve never changed my chain length if changing the flip chip and it’s been fine 🤷🏼‍♀️.
3. Yes, but you need to make sure there’s enough clearance through the suspension tunnel if your chosen shock has a piggyback. I use an Ohlins TTX22M with no issues.
4. Mine is a year old and done nearly 3000miles and I’ve not opened it or touched the motor at all. Opening the motor case will invalidate any warranty you have so if the bike is still under warranty I wouldn’t recommend this.
panther-ra
7
8
Oslo
What is the chain length on your bike and what is the front gear teeth / cassette?
Thank you!
P.S: what exactly happened to me when I decided to use flip chip
"Something quite dramatic is the Kenevo SL's bb height flip chip also adjusts the chainstay length. The bike ships in 'High' mode which sets the chainstay length to 446mm. But flip it to 'Low' mode and the chainstay length shortens to 441mm. "
After that my chain started to sag
SonOfBovril
7
South Africa
That’s strange, would have expected the spring in the derailleur to take up the slack in the chain?
You shouldn’t open up the motor and change the oil/grease unless you really know what you are doing, rather let a Specialized mechanic do it.
If I remember correctly the KSL will take up to a 34 tooth chainring, I think 36 is too big 🤔
ah1
145
88
Santa Cruz CA
Off-topic but I gotta say: 3k miles per year is impressive, even for an ebike! 💪
mustclime
550
436
New Jerzy
Cheapest option is to buy the Levo sl kids bike and swap the electrics
Reading through the thread, this has been done and it doesn’t work. The kids motor has hard ware in the motor that can not be programmed out. You are stuck at 7 mph.
Doomanic
🛠️Wrecker🛠️
8,947
10,890
From Spesh;
Two available max speed settings for motor assist: Parents can choose between 10 mph (recommended for younger children and/or children new to e-bikes) and 15.5 mph (for older and more experienced riders). Speed settings can be adjusted by an Authorized Specialized Retailer.
mustclime
550
436
New Jerzy
From Spesh;
Have you done it?……He did
Doomanic
🛠️Wrecker🛠️
8,947
10,890
He did...
...something wrong.
Firstly, the lower limit is 10mph, not 7. Secondly, if you have a fully functioning electronic system in one housing (the frame) and transfer the entire system to a new housing there is no reason for it to no longer function.
Doomanic
🛠️Wrecker🛠️
8,947
10,890
OK, I've now watched the video. The bike displayed just under 10mph on the TCU which is correct but the actual speed will be higher because of the larger wheels. The switch to 15.5mph at the dealer didn't work but that's got nothing to do with the frame the motor is fitted to.
Arron M
73
49
That’s interesting, I have my TCU display both what gear I am in as well as derailleur battery level and didn’t notice any additional battery usage. It lasts marginally less than the dropper battery and this is the same experience as with non e-bikes.
cañonaco
65
86
España
I have changed the complete set from the Levo Kids to a Kenevo and it works perfectly. Battery, Mastermind and 1.2 motor.
It pushes beyond 30 km/h because the 29” wheels have much more development than the 24” ones.
577K
