Looks like a new Mastermind display too.Guessing we will see the new 520Wh battery that has just launched in the Vado SL 2 in the Levo and Kenevo SL shortly...
Interesting. I wonder if they managed to squeeze it into the same space, be awesome if this was an easy upgrade for older bikes. New SL1.2 motor, mastermind MCU and this battery as an upgrade kit would be sweet.Guessing we will see the new 520Wh battery that has just launched in the Vado SL 2 in the Levo and Kenevo SL shortly...
Handlebar display thoughLooks like a new Mastermind display too.
It has been released half a year ago already but yeah would be a nice capacity for the SL bikes while being still reasonably light. The downtube of the Vado is much wider than the current Levo/Kenevo SL though so it will not be an upgrade for the current models I'm afraidGuessing we will see the new 520Wh battery that has just launched in the Vado SL 2 in the Levo and Kenevo SL shortly...
I have to do it also TCU battery after almost 5 years and around 20.000 km but my main battery shows now 90% and I feel that it drops lot faster :/5 years on, 16,000+km and 210 charge cycles and I finally had to change the TCU battery.
Also got a good tip on getting the battery out. No tweezers or screwdrivers required. Just unplug the TCU and open up the rubber port cover and with the battery opening facing down, tap the TCU firmly onto your palm or a rubber pad and the battery just pops out!
My main battery is still showing 100% health, which I wouldn't think would be true by now. It still seems to perform ok though.I have to do it also TCU battery after almost 5 years and around 20.000 km but my main battery shows now 90% and I feel that it drops lot faster :/
Any advice? I’m replacing my transmission with Shimano and just noticed my carbon (unlike the aluminum) version does not have any tubing for the rear derailleur.I had exactly the same issue and unfortunately you have to drop the motor![]()
Do you have a guide or any photos that you followed?I assembled the frameset and had to drop the motor for the rear mech cable and seatpost one. Someone on here suggested leaving the rear two bolts in and swinging it down, that worked really well for me and I didn’t have to unplug anything. All my motor bolts were loose so I assumed I was expected to drop the motor.
