samwilk200
YesIs the Kenevo SL leverage ratio suitable for a coil shock?
Works More than Good!Is the Kenevo SL leverage ratio suitable for a coil shock?
Not enough...
Not enough...
229mmwhat is the maximum seat post insertion on a s4 kenevo sl?
yes it s not enough229mm
not ideal no. depends a little on your seat height. I've just got a 200mm wolftooth resolve working in mine and it gives plenty of drop.yes it s not enough
Neither of these responses are worth the electrons wasted to post them without more information.oneup 180mm fits the S4 just fine
you should have just not bothered with my post when you saw S4 - yet you wasted electrons replying to it.Neither of these responses are worth the electrons wasted to post them without more information.
I can happily fit either of those posts to my S3. I wouldn't be able to reach the pedals with the posts fully extended but hey, at least they fit...![]()
Could you fit a sock in your mouth as well?Neither of these responses are worth the electrons wasted to post them without more information.
If only you’d put that in you previous post…Mine is sitting 73cm bottom bracket to seat rails with 200mm post.
It would have made the world a better place admittedly.If only you’d put that in you previous post…![]()
KSL comes with t tranny now?What chainring are people using on the KSL with the T-Type transmission?
No.KSL comes with t tranny now?
Rumors for Kenevo SL Gen. 1 or Kenevo SL Gen. 2?The rumours suggest the frame is unchanged, but they are only rumours.
it's a personal preference that you can only make a call on once you've ridden one. Some like it, some don't.What is the Kenevo SL like as a mullet?
Is the BB too low?
(I’m assuming it K SL is designed only be a full 29’r?)
I bet both my nuts that the only change to the “Gen 2” Kenevo will be the new quieter motor and that’s it.
There is nothing else to change on it as the frame is perfect as it is.
Until they can fit an actual true 50nm motor the battery size will not change.
