StuR
449
731
Forest of Dean
I feel obliged to complete the look.....
Not loving the orange decal
Beautiful bike
Do the orange decals peel off ?
If you don't like them , should be able to whip them off and replace with a bespoke set , whatever colour to you like for about £20
I've done it to just about every fork I've had
It really helps with my OCD 😁
Gutch
453
242
South Carolina
Beautiful bike
I concur
Gutch
453
242
South Carolina
It increases your negative air chamber in your fork. It feels coil like thru the 1st 2/3rds of the stroke. You will want to increase your airshaft by 10mm to compensate for the sag of the Secus, not necessary though. I’m still riding and testing, but so far it feels good. You will run less tokens in your fork and slightly more air pressure.
rydeezie
612
866
san francisco, california
Ok same thing the vorsprung luftkappe does. I really like the feel. It performs like my 2022 fox 40. The secus probably increases the negative chamber even more than the luftkappe. I opted for the luftkappe because it was only a $100 upgrade when i had the fork travel increased to 170mm. I am no longer using tokens but i did increase the pressure for mid and end stroke support. The small bump sensitivity is so good. So I guess I’ll go secus with my 180mm fox 38.
mike172
160
96
Has anyone added a 200mm dropper yet?
Cant work out if a fox transfer 200mm fill fit. I want the dropper slammed and out the way
Sep 19, 2020
99
94
Squamish, BC, Canada
I have a one up 210 on my S5. Haven’t tried slamming it though as it would be way too low.
Seat tube is way lower than my gen2 as the 210 slammed on my old XL was perfect.
what size is your bike? If it helps, I can check if I can insert it all the way.
mike172
160
96
Thanks that would be helpful. its s4
I'm set on a fox transfer if I'm honest
I know Will Greenfield on YT has a Pro with a 175 dropper and it goes in this much in the photo which is plenty low enough. The 200mm transfer is obviously quite a bit taller. I'll be honest the 175 xfusion manic is fine even at the depth I have it. So I may be ok with a 200mm
mike172
160
96
These non tuned Kashima 38s are quite something. First ride out last night on settings I was using with the 170mm Elites that came with the Levo Expert and they were ridiculous. Never had forks that float over chunder the way these do. Plenty of tuning to do but right out the box they are so so plush. Definitely upgrading the rest of the parts now.
ebikerider
706
484
Aren't they the same as the Elite version apart from the kashima?
Mike640
68
53
Portugal - Sintra
Nice!! 170mm fork?
568K
