TheSnowShark
Exactly, actually It's not compatible, only the Gen2 is compatible by reassembling the rockguard of the Gen3
ThanksI would say NO
The TCU of the GEN1 is in the battery, TCU of GEN2 and GEN3 is not in the battery - completely different system...
Have you checked your tunning settings in the app?Hi everyone. I have to admit that the levo gen3 is a total disappointment for me. I haven't even driven 200 km and the problems have already started. from the first ride, I noticed that the engine loses power at certain moments of pedaling. when the pressure on the pedal is relaxed a little, and the pedaling continues. there is sometimes a delay in power delivery. now it has already started to happen that when pedaling it loses power for a short time and moves on. I'm not too happy with this behavior of the engine from the very beginning. and immediately the bike for reclamation. it's horror!
Probably a little late but I didn’t and haven’t used a pullerHi guys!
Need to remove The spider off my gen 3, I have removed the lock ring, to protect the axle when using the puller I originally bought a 32mm socket, but I'm pretty sure that is just resting on a part of the spider so it won’t move when tightenedIs where I’ve marked red in the image below where the socket need to rest when using the puller? (The blue is where the 32mm socket would sit for reference)
I used a puller, but ill try your technique next time I need to get it offProbably a little late but I didn’t and haven’t used a puller
i just put a long Allen key or screwdriver behind the arm of the crank at 12 o’clock with a cloth behind it on the frame to stop any scratches
then slowly lift it up then do the same at the 6 o’clock postion or the opposite crank arm again prizing upwards gently then back to the opposite side
spider comes of super easy
done this a few times and always works in under a minute just remember to alternate opposite sides When you feel it starting to move
hope this description makes sense
Bad newsThat’s a decent ride. We might be neighbors. Lol. Was in similar area and finally saw a Mountain Lion for the first time Aug 19th. Only took video, no stills, so doesn’t show up on the relive. Let’s see if this works.
Actually, do videos work here? Nope, guess not, here’s a little screen shot View attachment 123748
in my experience not really! for a product of that rank, such errors as brose should not happen!
I never resolved it no. It annoyed me so much I barely ride the Levo now since about 6 months when I got an Enduro. Fact, I've kinda gone off e bikes since owning the Enduro.
I'm currently replacing all bearings on the levo as i write this. The cascade linkage has slipped a bearing and the big bearings near the motor and the 4 bearings at the end of the seat and chain stays were toast. Haven't ridden yet so no idea if it fixes it.
I spent a lot of time inspecting the chain stay and couldn't see a crack although I may have another look since Veli-Matti mentioned the crack before the bike goes back together.
My chain stay arms do flex slightly if you push them together but can't work out if that's normal. I didn't press too hard as I didn't want to crack them. But they definitely weren't solid.
Once I've managed to ride it I'll come back and update.
Edit..... yeah its looking pretty cracked. FWIW it flexes only on the right hand/derailleur side. The other side is pretty solid.
View attachment 131762 View attachment 131764 View attachment 131765 View attachment 131766
There's a chain thread but the XO has been a champ.Is there any specific chain anyone would recommend as a replacement
I have been to 2 service centers, they say that everything is fine. although an error was read, a voltage drop in the light connector. they cleaned the contacts and sprayed contact spray. but, interruptions during pedaling still exist.Have you checked your tunning settings in the app?
Spoke to Spesh support. Full bike build wheel specs are different from Roval wheels sold separately so this info isn’t available on their website.Gentlemen, I just found a broken spoke on back wheel 27.5. (Roval Traverse) on Gen3 Levo Expert.
Anyone know what length spoke they are?
DT SWISS COMPETITION RACE SPOKE
DT Swiss Competition Race Spoke (Black) (J-Bend) (291mm)
The DT Swiss Competition Race individual spoke has an extra thin middle section to save some weight with remaining stiff and durable. Features:... SCR020291S0100www.performancebike.com
I had same problems and had the speed sensor changed, but I still didn’t have time to test properly yet.I have been to 2 service centers, they say that everything is fine. although an error was read, a voltage drop in the light connector. they cleaned the contacts and sprayed contact spray. but, interruptions during pedaling still exist.
I don't know if this is normal for Specialized?
when I tried the settings in the application, I noticed that: when I increase the responsiveness to 80 or 100%, interruptions appear more often than when I set it to 20%.
has anyone had such problems?
maybe the problem is in the speed sensor, the magnet...
the interruptions occur when I reduce the pedaling power on a hill, but I still turn the pedals but more slowly, the engine runs. and at one point the engine seems to stop for half a second, maybe even less.
it doesn't happen all the time, occasionally.
very similar things happen.I had same problems and had the speed sensor changed, but I still didn’t have time to test properly yet.
Other symptoms I had was difficulty to reach the 25kh/h limit unless trail tipping downhill, and motor cutting the power when rear wheel looses traction and spins the middle of a difficult climb, this was the most annoying…
both sound like torque sensor issuesvery similar things happen.
I don't know if it would go in for repair at all! I've been to 2 authorized service centers and they didn't find anything, and the bike is still under warranty.both sound like torque sensor issues
I would prefer to sell the bike. it has 170 km! Today Specialized Eastern Europe also gave me an explanation. here is the email.both sound like torque sensor issues
no emailI would prefer to sell the bike. it has 170 km! Today Specialized Eastern Europe also gave me an explanation. here is the email.
Hello,
Firstly We need to point out that service done everything they could. It is recommended to clean up the contacts to keep the system function fully.
Main issue is that We see only few errors on your bike and even close to each other so keep in mind that If errors keep showing in future, visit your local bike shop to check the bike again. But for this time We would recommend to use the bike as normal.
Thank you for reaching us and have a nice day
?no email
you said...here is the email......but there is no email attached.
from hello, the following is an email!you said...here is the email......but there is no email attached.
Hello,from hello, the following is an email!
