Kenk3589
61
40
Usa
Hey guys what is the actual default display you get with this? Cause mine doesn’t come with the central power button or the square display.. it came with I think the dp 180 which jsut goes on the handlebar.
mike_kelly
984
831
US
Button button whos got the button?
stuff
166
281
Spain
Mine did not come with chainstay protector or down tube protector.. :(
Dont worry, mine came with the bafang battery with broken tabs and the magnet for the speed sensor was missing. Guess i’d have preferred no chainstay protector or downtube.
Both of them are on aliexpress tho:
€ 2,63 42% Off | Bicycle Chain Protector MTB Chain Guard Cycling Frame Chainstay Protector Scratch-Resistant Cover Bicycle Accessories
€ 1,71 50% Off | Bicycle Chain Protector Black Cycling Care Chain Posted Guards MTB Bicycle Frame Chain Cover sticker Cycling Bike Accessories
temon10
677
570
Malang, Indonesia
Finish my build and have short test ride. Feel comfort with the frame, size S as I just 160cm height. Motor feel not as smooth as my M510 FC 2.0 but just a little, maybe need firmware update (will find it).
Total weight 20.35kg with 720Wh battery, Fox 36 Kashima, DPX2 210x50, Mullet E13 LG1 Alloy wheelset with Spank hub, Sram X01 11 speed groupset, Magura MT5 Brakeset, Renthal 35 Carbon Handlebar n Stem, Syncross dropper seatpost and cheap pedal and saddle.
stuff
166
281
Spain
View attachment 115511 View attachment 115512
Nice!
How does it feel with the mullet setup?
Fox at 160mm or 170mm?
forsa355
62
116
Canada
for those that have received their frames, I have a few questions that would be appreciated if you could verify:
1. Did you use a 8mm x 22mm or a 8mm x 22.2mm bushing on your rear shock?
2. Did you receive a power button for your top tube or just a metal plate covering the hole? If you did get a button, please describe it or post a picture. Did anyone get the Bafang power button?
3. Have you been able to use any of the Bafang phone apps using bluetooth (e.g. Bafang Go+ app)? If so, how did you connect to the app (e.g. using display BT) and what kind of parameters do you have access to setting in the app
thank you!
stuff
166
281
Spain
1. Did you use a 8mm x 20mm or a 8mm x 22.2mm bushing on your rear shock?
thank you!
Hey!
1. 8x22.2, exactly this ones:
2. Just a metal plate. I want to get the DP E171 and just use that instead of the DP E180 that came, like the cockpit as clean as it can, dont care of only having 3 power modes instead of 5
3. Im waiting for the DP E181 to arrive, should be this week. With that i’ll have bluetooth so will update on what can it do with BAFANG go+
Kenk3589
61
40
Usa
Hey guys are any of you guys running rockshox and using a m8 x 22.2 eyelet?
I think if I ordered from Ali baba, it would take a couple weeks… anyone got a U.S. source?
LAnton
560
468
Russia
Lanton, can you explain why this is necessary? Does the frame not come with a suitable derailleur hanger?
I had a poor quality axle. And one day I couldn't unscrew it. I reported this to the factory. You need to buy a new axle. Or you can make a new thread on the old axis. A spare part is always needed
LAnton
560
468
Russia
Hey!
mike_kelly
984
831
US
All the usual suspects carry them.
Kenk3589
61
40
Usa
Haha I only saw 8x22 and didn’t think anyone else had 22.2. Thank you! Did you get your frame yet?
571K
