spokémon
191
100
Jean told my frame was painted and the motor would be ready in two days but the 410wh battery is being revised and delivery time will be longer.
I hope not a lot longer.
I got a similar story from Linda re 410wh battery delays. She also ordered a 165mm crankset for me from Bafang instead of the 170mm but it is also delayed.
spokémon
191
100
I see lots of bottle batteries with 36v and 48v on AliEx. Does that mean those of us with 43v systems are out of luck for bottle batteries?
mike_kelly
1,001
849
US
That is why I picked 36v. I knew I wanted an external battery and 43v is not standard.
patdam
945
608
france
if choosing Bafang 43v battery, U have to wait Bafang release their extender battery.
The interest to use bafang battery, is that BMS can communicate with the HMI and you can displayed several informations of the battery use. For what i know, nothing other batteries can do that. in addition of you don't need to build adaptations to usfix the battery.
LAnton
560
468
Russia
Hi @LAnton or @stuff Any chance you can show a photo of the internal battery mounting bracket for this frame?
I've almost finished assembling the bike. The battery is attached with 4 bolts to the frame. There is no bracket on the frame, only holes in the carbon fiber. Also, 2 bolts for the bottle holder are attached to the battery through the frame.
stuff
166
281
Spain
Battery wasnt 100% in here, but you can see irs a tight fit with the 3d printed supports
This were some initial prints testing fit
LAnton
560
468
Russia
Added some zip ties to strengthen it up since its attached to only 2 bolts.
Also 3d printed some supports so its a tight fit
I have a different battery. It is made entirely of aluminum. The battery is attached to the frame with 4 M6 bolts and 2 bottle bolts.
WhatsApp Image 2023-04-29 at 21.58.26.jpeg WhatsApp Image 2023-04-29 at 21.58.34.jpeg
576K
