My Aussie Cheeb
Hondy
49
24
simba124
85k’s sounds pretty damn good!
I have just ordered a new saddle, I couldn’t ride more than about 20kms seated constantly. When i ride the new saddle in i plan to do a bit of a range test myself. Will post a comparison. My home town is pretty flat also.
I am curious, how is the PAS and torque applied with that controller Compared to the stock controller? As smooth?
Hello
Hello , just put out my info on the range for M600 ....I drive another controller 43V 20A from FLX (=battery 48Volt 840wh).
I can reach about 85km on 1 battery and about 600hm in totall (mostly pas2 from 5) ,there is no real mountain overhere but more like smaller hills ,country riding ! View attachment 83532
Hello Guys ,did some testing on the PAS1 off 5 from controller above ...got 140km on a flat surface (+-300hm) .You have to work a bit harder .The big power isn't there in PAS1 but if you are getting started ,and keeping the speed at 26-28km is easy on a 90ish cadence .
RoyRoy
29
@Hondy I did a 41km ride the other day on a mix of fire trails with some uphill segments. PAS1 mainly (PAS2-3) for some short climbs. By the time I was home battery was about 56%. Stock controller. average speed was 21km/h.
So not sure how far I could get. Dont want to push it too far from home as riding without a battery is HELL ON WHEELS 🤪 most of my rides are 15-20km, but i do plan on the odd tour type ride, so I probably need to find its limits on stock controller.
Hondy
49
24
simba124
The limits on flat road full tires (90kg + bike kg25) batt dengfu 840wh with the stock controller about 70-75 km Average about 29kmh...
Dado
729
489
Bratislava
Hello ebikers.
K1 eBikes has designed small, portable and simple K1 CAN Monitor & Speed Unlocker - no need computer or mess with BESST. Works ONLY with Bafang motors with CAN bus (green connector to display with "house" shape 5 pin connector).
For more info check the following link:
https://endless-sphere.com/forums/viewtopic.php?f=31...
How to unlock speed:
https://youtu.be/6z3TzEqNWsQ
If you interested, send an email to [email protected], will answer any questions and will send user manual.
K1 CAN Monitor is determined for testing purpose only and is not waterproof.
571K
