mustclime
550
436
New Jerzy
My 2022 Levo has 2160 mm pre-configured for wheel circumference. The same for my buddy's 2023.
I've measured the actual circumference on my stock 27.5 x 2.6 Eliminator to be 2251 mm. And I've been looking thru some tire charts and can't find any 27.5 tire with a circumference even close to 2160 mm.
So my question is, why is the wheel circumference for the Levo set to 2160 mm resulting in ride distance measurement that is 4% lower than actual?
Look here…
2247 is what it says for a 27.5x 2.6
16Rally
42
22
SoCal
Look here…
I agree, I measured mine at 2251 which is pretty darn close.
However, the question is why our bikes come configured at 2160?
And to change the setting in the Levo controller requires a trip to the dealer.
Oakhills
68
35
Oakland, California
I bought my son a '23 Levo Carbon base in S4 and am looking at upgrading the rear shock. Found a great deal on a Fox Float X2 Factory. Are there any clearance issues with this shock on this size frame.
If the shock is a 2021-2023 model, there is a voluntary warranty recall and Fox will exchange it for a 2024 model. Contact Fox when you get the Shock to see if your shock falls under the warranty.
Cb750stu
504
475
United Kingdom
I sent my X2 back through my LBS for the usual warranty issues on these , when I received it back it wasn't a new shock it was the same shock with the new updated parts/seals etc.
Feb 10, 2023
34
24
Manhattan Beach, CA
Can you send me a link to more info on this? I have a 2022 version of this shock on my Orbea Rise, bought the shock new about 12 months ago, so that one is definitely in range.
16Rally
42
22
SoCal
I'm contemplating a carbon handlebar for my 2022 Levo Comp.
I've been able to lookup the backsweep and upsweep specs for the stock alloy Specialized bar currently on my Levo, but does anyone know the rise?
TIA
Feb 10, 2023
34
24
Manhattan Beach, CA
Hey, what's it like replacing the rear brake, specifically pulling a new line? My Orbea Rise required me to drop the battery and motor, wondering if the Levo Carbon is a similar endeavor, in which case I might just upgrade within brand as opposed to going to "Shiguras"
Andeh
61
49
Half Moon Bay, CA
On the carbon ones, there's a plastic tube that runs continuously from the rear to the port by the head tube. So you can stuff most brake hoses through from the rear and it'll pop out at the front. The only exception is really large diameter hoses like Hayes Dominion don't fit in the tube, so you've got to yank the tube out, drop the motor, and route the hose carefully.
Dmaguirenz
31
11
New zealand
anyone tried the new rockshox Vivid on there levo?? are they in circulation yet?
Yes , just fitted mine with the levo tune. Fit is good on the S4. Seems to be quite progressive as it's shipped. Def quite plush in the first part of the travel and the mid stroke- bottom out is an improvement over the stock X2. ( heavier rider - I'm over 300psi on the X2 to make 28% sag)
BikingBad
82
35
How many volume spacers are you using?
Nickolp1974
237
174
Louth lincs
did you get the Pre tunned levo model or generic??
Nickolp1974
237
174
Louth lincs
thought this was on all gen3 frames??
579K
