Levo SL Gen 1 Official Levo SL Thread
paquo
463
284
usa
How’s this.
I am 181cm with 85cm inseam.
Some how my testbike, size large feels a bit small for me and feels smaller than my large size fullpower levo.
XL might be too big.
i think the geo is really similar if not identical, what is way different is the chainstays which makes the bike feel completly different
Gallijam
49
31
East Midlands
Im might go mullet .. have 27.5 on the back as then my feet can touch the floor . As when dropper is down my feet do struggle to reach the ground . But my Kenevo was the same and that was a medium .. I’m just a short arse with a big torso and just about the right arms .. I can live with it being a bit high as my feet can touch the ground on the inside of berms .. if the collar wasn’t so big on the axs dropper it would be Perfect but if I do struggle then I will put a 27.5 on the rear .
Well Iv gone 27'.5 front and rear and flipped the chip round and he's spot on
Killswitch73
374
231
West Midlands
How’s this.
XL Is for you my friend with that height of near 6ft and 33.5in inseam . Could just get the large and get longer stem and dropper .
Johniboy73
11
Leeds
Just realised the SL has far less tunability. The acceleration response has been removed as has the shuttle adjustment.
Or am I missing something? Also, anyone know how to get the ‘rider power’ to work on the fake channel with a garmin? Even when I’m still it’s showing a power.
TomH79
322
304
Finland
I got the edge530. Is it possible to connect levo to it???
TomH79
322
304
Finland
Longer stem is not an option.
Think that XL might be somewhat too big.
At least if my fullpower levo was an xl, it would be too big.
iainc
171
134
Glasgow
At 5ft 9 and a bit and a 30 inch inside leg, the Large looks right on paper for me, bar the 150mm dropper, which will have an ISM Saddle, with a slightly higher stack height than the Spesh one.
Johniboy73
11
Leeds
Yes, even Got a field here (bottom left on my photo) showing the percentage left on the battery and what mode it’s in. But the power isn’t reading correctly. If you don’t use a fake channel, it cumulates the power you are putting in and the power coming from the motor (not a lot of use). Had it working with a 2018 Levo, but can’t seem to get the SL to. Noticed the garmin not reading some other battery info and assist level. The first photo shows what the old Levo was recording, the second the SL
ImSundee
328
316
Oxford
Power doesn't work I've found with mine.
What I do is run the specialized app and garmin, then combine then before uploading.
Waynetta
194
180
Plymouth Devon
Wasn’t this due to an app update And nothing to do with being an SL or a full fat. ??‍♂️
Vin829
107
42
California, USA
I’m 5’9 and went with a large. The med felt wayyyyy to cramped. Also I got my power meter to read with my Garmin. But the max power I’m seeing is only 150w. I know I’ve been way over that
TomH79
322
304
Finland
Did today second test ride with sl comp.
Eco was set on 30/35,trail 40/50 and turbo 70/80.
I rode over 50km and about 900m climbing.
At the end of the ride i there was about 50% charge left.
Kind a like it way the ride went. I was able to ride up whery technical and steep climb, but also my heart was beating 95% of its maximum hr.
At the top, i wasnt as tired that i would be if had did that with analog bike.
today i find out that the bike accelerates very well over the speed limiter.
I at point that im still able to tackle those 100km rides with 2000m climbing with bike like SL. It will give a very good workout every time i ride it. With full levo im also able to get workout done but it is also easy to put it on turbo if you start to feel tired during ride. With sl that is also option but you will smoke the battery fast.
Other hand: if you ride today 100km with full levo and feel exhausted, you are still able to ride tomorrow, just add assistanse and have fun.
100km with sl and i definetly need a rest day or two.
At the moment, im fucked. Really cant decide what to do? I got a buyer for my levo if i decide to buy sl.
So bike gods, help me with all the details you can.
E: if the sl is the next bike, its specs are(comp carbon)
-lyrik ultimate with vorsprung smahspot
-cane creek coil IL
-dt swiss ex511 wheels
-shimano xt 8120 brakes
-renthal stem and carbon fatbar
-crankbrother candy 7
-X01 casette
E2: will 2.6” specialized tyres fit to SL levo chainstay?
Killswitch73
374
231
West Midlands
-cane creek coil IL
-X01 casette
Ffs are you only 50kg or something ?
jemen
317
379
Austria
-cane creek coil IL
-X01 casette
I would go for the SL. I rode the Levo for several years, it feels too "clumsy" in comparison to the SL. The SL is definitely the right decision for riders who have no problem with "some" pain in their legs.
TomH79
322
304
Finland
If you check my post where is the specs that is coming to sl.
Riding is mostly enduro type, still go for the sl?
jemen
317
379
Austria
If you want the "real" bike feeling (steering, jumping, doing manuals etc.) go for the SL.
If you want more the brachial type of feeling go for the LEVO. The LEVO is the powermachine, the SL is the more agile, numble bike.
Johniboy73
11
Leeds
Got to agree with that. The sheer weight of the Levo is tiring after a while too. The SL i find you can go a lot longer on and throw it about more
SquireRides
540
557
I am stunned by the Levo SL range.
I'ma big guy, about 100kg fully kitted. I charged up the internal battery and took a full range extender 'just in case' for my isolation ride on Sunday.
After 38km and 580m elevation gain, I returned home with 13% of the extender left and 100% of the main battery!!!
Seriously thinking of dropping the main battery out for a few rides, see how it feels!
YMMV. My isolation rides tend to mostly be on wider fire-trail/gravel/lanes. But the idea that I can do my normal local Sunday ride on 160Wh blows my mind. I'm pretty sure I'd have got through nearer 300Wh on my Bosch....
TomH79
322
304
Finland
Assist levels?
SquireRides
540
557
Assist levels?
Mostly Eco 30%/50%, and a bit of Trail 50%/70% for the hill climbs.
I have been tuning my Eco down recently. I had it at 25%/50% which still allowed me to climb hills with roadies, but I found 25% support to be under-powered when accelerating. Kinda felt stupid having the whine of a eeb motor as I accelerated away extremely slowly. 30% support is now my Eco sweet-spot.
jemen
317
379
Austria
...The sheer weight of the Levo is tiring after a while too...
You are so right! The carrying, the movin around, even pushing the bike up again on very technical steep trail passages with its "pushing aid" is so hard.
I remember the day i grabbed the SL and pulled it out of the box. It felt like a road bike.
p3eps
1,988
2,410
I think this is one of my biggest gripes of the Levo SL.
People see / hear you are on an eMTB so automatically assume you should be racing along and climbing everything without breaking a sweat!
I’ve had to explain to several people that I’m ‘only’ getting 35% help!
579K
