Levo SL Gen 1 Official Levo SL Thread
Fojsum
13
8
No rotors. I’ll weigh both the front and rear, stripped down with no cassette/rotor etc tomorrow.
Hey 73steff, curious if you were able to weigh both front and back stripped down yet? Was hoping to get a definitive answer before I decided to order a new set. Thanks!
Gary
Old Tartan Bollocks
10,496
10,709
the internet
I don’t think Rock Razor is going to be much use in muddy Scotland!
As a rear tyre they actually work pretty well in mud as there's very little centre tread to clog and they have a good edge to rail turns when leant over properly.
what they do lack is straight line braking and climbing traction.
so if you tend to ride scottish forests with a lot of fire road/doubletrack climbs to access steeper more natural twisty descents they're apretty decent choice all year round.
Kpmnd85
45
35
Austin, TX
yes I wanna see someone do 27.5. If I get an SL I will likely go that route......
I have an S-Works 6Fattie with 27.5 x 3" tires. Tonight I've swapped out the alloy 29ers on my SL carbon comp for the 27.5" and I will give it a ride tomorrow.
The tire clearance is about 3/8" on the sides in the back. Plenty of clearance in the front. Its dry so should not be an issue. If this setup was going to be permanent I might want a bit more clearance in the back.
Part of my interest was to get a feel for running carbon wheels and an overall lighter setup. The overall bike weight dropped from 18.01kg to 17.11kg. The weight drop comes from the following sources:
*** One note the weights are a little off because I forgot to initially swap the large discs on the 29s for the smaller discs on the 27.5"
Cassette goes from NX to XX1
Front wheel goes from alloy + 2.5 tire @ 2.29kg to Traverse SL + 3" @ 2.02kg
Back goes from alloy + 2.6" + NX @ 3.185kg to Traverse SL + 3" + XX1 @ 2.4kg
Looking forward to riding this setup.
p3eps
1,987
2,410
I’ve got a SJ Expert 6 Fattie with the Traverse 27.5 x 38 carbon wheels on it, and 3.0 tyres.
I was wanting to try the rear on my SL, but thought the tyre would be too wide.
Good to know that it’ll fit - although it’s very rarely not muddy round here!
I’ve only ridden the SL with 29’s twice so far, so would like a few more shots before trying the 27.5 rear to get a better comparison.
MEDUIX
37
36
BARCELONA
Yeah but XO/11spd XT is still worse shifting than Zee/Deore and it's 3 or 4x the price. My entire drivetrain (shifter, mech, cassette, chain, chainring) is £78
Right around the same weight as yours too. But more durable.
Could you write here the exactly drivetrain? which component is Zee and which is Deore?
jemen
317
379
Austria
Anyone removed the chain guide from the SL?
I always rode my LEVO without changuide because i used narrow wide chainwheels, worked perfect.
Don´t know if it wold work now with the standard SRAM 30t chainwheel....
Fivetones
898
905
Cheshire
You’ll see if you google 10 speed Shimano you’ll see. There’s quite a few options from cheap SLX (RD-M670) to expensive, but still affordable (to ebikers!), XTR (RD-M986 mech etc). HG54 chain etc
Gary’s the expert here though (and can tip off to cheaper no doubt) but he led me to look into this through his abundant comments on this on here. ;)
ImSundee
328
316
Oxford
I've removed it, but not ridden without it. its alot cleaner than normal levo, it has a alu bracket that screws into a motor mount. so when removed there are no holes left.
I do kinda wish they had included chain guide mounts on the motor would be cool to see something off the shelf on there/pimper.
jemen
317
379
Austria
I do not have my SL here at the moment, is the chainguide easy to remove?
The chromag chainwheel should work perfect...Sequence
Vin829
107
42
California, USA
Saratoga. Hitting Henry Coe tomorrow at 8:30 am at Hunting Hollow Entrance. I demoed an expert Levo SL during the windstorm - did about 25 miles and 6000 ft of climbing. Had 17% left on battery (with range extender).
What did you think of riding it at Henry Coe? That’s where I took my demo and I was extremely impressed
jemen
317
379
Austria
Looks very clean.
Rob Rides EMTB
Administrator
Staff member
6,290
13,840
Surrey, UK
Very Shiny! What is your reasoning for Rockshox over Fox? I'm wondering if to change to 36s for Lyrics later down the line.
To be honest I tried the 2.1 Lyrik 160mm recently and I thought that there was quite a lot of dive in the first third of travel over low speed compressions. I'd set it up for my weight / riding style. I had to crank up the LSC to almost full to make it feel close to how I wanted.
I found the Fox 36 much more compliant in the initial to mid stroke.
But I have been used to the way Fox performs over RS for a while - could be down to muscle memory / how I've adapted more than Fox being better..
I will let you know how I get on with Pike.
p3eps
1,987
2,410
Price. And have always used Fox so wanted to try RS with the 2.1 damper.
I was searching for both a few days ago, and could find the Lyric Ultimate for almost the same cost as the Pike Ultimate.
Is that a 150mm or did you step up to 160mm?
Rob Rides EMTB
Administrator
Staff member
6,290
13,840
Surrey, UK
Its 150mm. Would be too twitchy for me with 160mm.
Yeah I did think about the Lyrik but in the end Pike will suit what I'm riding. And @Gary also recommended it :)
p3eps
1,987
2,410
Looks good anyway ??
I’m going to stick with the Fox 34 short term and see how I get on. The Lyric 160mm on the Rail I had felt really plush, and was the nicest fork I’ve had. Doesn’t necessarily mean it’ll feel the same on a bike that’s ~4.5kg lighter though!
568K
