Picture courtesy of TCFlowClydeWhat a neglected bike!That guy really needs to wash all that nasty dust off! Wait what? Oh, OK, I'm being told that's just after one short ride on his typical local trail system!
You can not connect an external battery to that port. It is only for charging and can't handle more than 2amps.The battery is 48v and 700wh, I want to put an extender on the bottle holder, has anyone put it there?
48v 700whBateria de 720 Wh?
Hi, is the 700wh battery the one that comes with the frame? Do you know its weight? Are you getting a lot of autonomy from it?48v 700wh
I have already chosen it, it is 700wh and 48v, everything comes with the frame, I think, battery, motor and frame, it is made of jeanNo battery comes with the frame. You choose which battery you want.
Yes, it is the battery that comes with the 48V 700Wh 4kg frame. Regarding autonomy, it depends on the type of ride. I ride XCM autonomy above 100km with 1500m of elevation, 10% single and 30% off and 70% eco.Hi, is the 700wh battery the one that comes with the frame? Do you know its weight? Are you getting a lot of autonomy from it?
top weight components?Interesting, they are 500g lighter than stated. My total build came in at 21kg.
My components are really heavy, I left the light components on my XC bike. Here is the list:top weight components?
I'm going to try to leave it at 18 kilosMy components are really heavy, I left the light components on my XC bike. Here is the list:
- mt620 wheels
- exa form seat post
- shox deluxe 210x55
- fork durolux 36
- front tire hellkat 2 4
- back tire Ruban 2.4
- Rim protector
I believe it would be possible to reduce about 2kg for several $$$.
It has a smaller 480wh battery carbon case with 1.95kg.I'm going to try to leave it at 18 kilos![]()
I like it with more battery, I do marathons and long runsIt has a smaller 480wh battery carbon case with 1.95kg.
I regularly do 25km (~15miles) with 900m of elevation (~2950feet) and I'm almost every time in boost or S+, I got home with 20% left.My wife did a test in the Montana mountains. A 22 mile ride with 2000ft constant elevation change with a 360wh battery. Had 20% left in the battery.
75kg fully dressed, average to good physical level (I manage to do my 25k with 1500m elevation in 1h05min).How much do you weigh? are you trained? with my weight of 70kg dressed with a backpack I can travel 40/45 km and overcome 2,000 m of altitude difference in Eco/Tour (100/200w supplied) with sections in Sport (400w supplied). 48v 480wh battery with 43v firmware
Could you talk more about the advantages of having a 48v battery and 43v firmware. Could it compromise the engine or battery?How much do you weigh? are you trained? with my weight of 70kg dressed with a backpack I can travel 40/45 km and overcome 2,000 m of altitude difference in Eco/Tour (100/200w supplied) with sections in Sport (400w supplied). 48v 480wh battery with 43v firmware
Good route, I have ordered one to see how it is.Tour 40% asphalt and 60% dirt road, no trails, 120km, 1800m elevation, 700wh battery.
Strava: https://strava.app.link/jskxSuzxSRb
Hey Guys, what's your longest / highest ride with the M820, even in Eco ?
I'm planning to do a 60+km with 1450m D+, I will have no other choice than staying in eco all along but I'm afraid it won't be enough. I'm running the Bafang 430Wh battery![]()
