Bafang M560
kuba4333
Poland
Is it possible, for example, in the event of a failure, to make the m560 engine work without a speed sensor? apparently, there is no problem with this in the m620
xtraman122
278
221
I don’t know of one, it’s annoying that it requires it, but I guess is all part of the silly speed laws related to e-bikes.
Tjhell
11
Thailand
Hi all, first post here. Recently bought an eMTB with Bafang M560, this thread has got some good information in, thanks for sharing.
I’ve deduced mine is a new 500W as it has a sticker (not etching) and has only been offered for my bike for a couple of months, replacing the M510.
I have two friends I ride with, one with an M620 and another with an M600. The M620 is crazy loud, but the M600 is incredibly quiet compared to my M560. I’d say my motor noise is not offensive but I am a bit disappointed it’s so loud vs the M600 and I really can’t understand why.
We had the M600 open recently to clean, grease and check bearings and I was surprised to find it has a steel gear (not nylon) but yet it’s almost silent, even as configured to 750w.
Other than that I’d say the M560 has been great so far. It has modes 0 to 5 and I haven’t found the need to use 5 out in the wild. With my SRAM 11S gearing 10-42T with 34T chainring this thing can climb really well in mode 3 & 4. That said I’m going to fit a 32T this week and test that on some steep stuff.
Tom
Tjhell
11
Thailand
This is what I see from the info section of the bike display. 1009BF.
As for overrun, it's a fraction of a second, just enough to skip a pedal if I need to glide over a rock. I certainly wouldn't want less overrun. With my limited experience i'd say the overrun is perfect and consistent with my friends M600 on a similar bike.
Tjhell
11
Thailand
As you writing, M560 is starting to reduce power from 20%. From 10% it is noticeable a lot. All Bafangs are doing it.
One trick to avoid this is to put there BBR and in Battery mode 2 (will show Voltage instead of SOC %) power limitation is gone. Using it when returning home and when I know I can make it also with full power.
I can confirm my M560 has reduced power from 20% down. The behaviour seems to be capped at mode 3 of 5. Modes 1-3 seem to work normally, modes 4 & 5 seem capped at mode 3 assistance.
dvng
109
49
Malaysia
C
Can you screenshot from the bafang app? This info is not very clear with regards of the controller fw.
Waynemarlow
1,156
927
Bucks
You need to put 250kms on it before it will start to quiten down, the gears seem to need to "wear" into mesh with each other. Both my M600 and M820 were awful sounding until they had a bit of mileage on them. The M510 I have was quiet straight off.
dazirl
35
21
Ireland
If only that was true. Mine got louder after 250km. And kept getting louder till it completely failed just after 2000km. If your motor sounds like an army of DeWalt drills chasing you down trail, then putting more use into it won't fix the problem. If it's anything like mine, there would be bearly any grease in the motor from factory.
I think mine has a failed one way bearing from the problems I'm having, motor spins but it won't move the chainring
Bafang are replacing the motor for me under warranty atm
Waynemarlow
1,156
927
Bucks
Bit like all those E10 frames that you are purporting to be breaking up, seems I have both good quiet engines and a good frame.
@dazirl you must be one of those unlucky souls that always seem to be the recipient of the worst one of any brand.
Tjhell
11
Thailand
The bafang app is useful if You want to change ride parameters without hooking up to BESST.
Unfortunately I can’t access the Bafang app with my bike according to the brand (Hybridizer). I tried anyway and the app won’t find my bike so I guess they have a tweaked FW. The screen (in frame) does have a Hybridizer splash screen so I assume this.
According to them my FW version is MMG5300C4819F801007.4
I need to look into it more.
dazirl
35
21
Ireland
Wayne, don't worry your pretty little face. It's been replaced by Bafang.
Waynemarlow
1,156
927
Bucks
And how is the new engine, you yourself were quoting what was it 20k miles a year on bikes, I’m sure you will already have done at least 500km’s.
Honest review please backed up with sound recordings at 1m, compared to a Bosch engine at the same distance with a recorded power meter comparison of the two, under the same conditions. Without that scientific proof then your words are just that, words.
dazirl
35
21
Ireland
When the replacement motor comes we will see how that sounds after the 250km break In period. The bike is currently in pieces as I'm giving it a full service before the new motor arrives.
Just got word today that my replacement motor is being shipped. Over the weekend I will dismantle the old motor and we shall find out what's failed. I'll gladly show you what's gone wrong with it. From talking to other m560 users that have had a similar failure it's the one way bearing that's failed. The motor runs but it does not engage the chainring, be it from throttle, pedals, or walk mode. From what I've been told it was a problem with first and second versions of the motor. Yes it's weird that it's happened to a third generation one, so it will be good to see if it's the same issue
Dado
735
497
Bratislava
You need DPC245 v3.0 and also good firmware there - v1.2 works. And maybe also correct controller firmware.
Anyway that version 7.4 you have I am not sure if is OK, that 7.4 versions was very first beta test version. I would reflash to 25A (instead of your 19A) version - much more fun.
Tjhell
11
Thailand
Thanks. What would be the difference and how do you suggest I update it?
dvng
109
49
Malaysia
If i am not wrong, the 25a has different bootloader. The first gen may not be able to flash it.
Dado
735
497
Bratislava
Yes, there was some controllers with different bootloader. Looks like it was USA version of motor in the begining(now there is max 750W version, and 500W).
I have firmwares also for this motor version. Also one USA motor on the bench for testing. ;)
dvng
109
49
Malaysia
Do you have the 750w for this firmware. 1st gen m560.
Dado
735
497
Bratislava
Yes, I do have. From HW or SW version we dont find out if it is USA boot code motor version. You just find out when you will be flashing if refuse or not. But definitely I would flash with 25A firmware version . You have now 18A.
xtraman122
278
221
Here’s what my 750W “quiet version” shows. I set the speed limiter/circumference in BESST Pro but it's the firmware that it shipped with. I think this is still the current one for 750W or did they release something newer since? I know I've seen a newer 500W come out since I got mine.
Dado
735
497
Bratislava
Yes, have not seen other version then v1.5 so far.
Have just some v1.5 compiled for battery capacity (which is stupid from bafang, why we can not set battery capacity over Besst?). Usefull for people with DYI battery with no CAN communication to show "good" range estimation. Range estimation by Bafang was never accurate. ;)
xtraman122
278
221
They have a field somewhere that helps estimate the range based on a static value of capacity? I haven’t even noticed on my non-CAN battery how good or bad it is, my rides are always well short of the possible range so I’ve never worried about it at all. Is the cutoff still just based on voltage or is that somehow tied to this too?
Dado
735
497
Bratislava
Thats right, there is bad estimation of range. And as you writing, they just have hardcoded some capacity battery and then calcualting range. For example, when I lower PAS 1 to 20% power at M510 I got range calculation 360km. ;) With CAN batteries controller get info about battery capacity and then recalculating from this value. I was also never looking at this range calculated by Bafang as it is way off. But many people started to complain about this, so now they compiling firmwares with different sizes of battery capacity (have also firmwares with different battery capacity for M500 and 510 FC2.1). As I said, wouldnt be much more simple for them to add new register and just set it over Besst to real capacity of battery you use?
Cutoff is matched to voltage value. Designer just needs to choose where is the end. Or from which voltage to start limiting power and where to hard cut. And the problem is CAN Bafang motors have set it too high (3.3 V per cell).
With CAN battery it is different, controller switch purely to SOC, which is sending by BMS. So when BMS reporting 0% motor will stop. Also depends how is controller set and from which SOC percentage controller starts to reduce power. I saw it different with each firmware, sometimes from 20%, sometimes from 10%, and saw even 5% and 0%. Bafang developers just freestyling. ;) And looks to me every new motor or firmware is designing and coding completely different team of people as I dont see here consistency.
I was thinking about this a lot, did many tests and come up with K1 BBR which is tricking controller and allowing to discharge deeper, down to 3.0V per cell and even deeper. Tesla with NMC batteries also going down to 3.0V per cell and then allow you go little lower as a buffer.
575K
