SZZS CEF50 lightweight using Bafang M820 motor (Specifications Thread)
voigtkampff
101
105
Poland
The shock mounting bolts are very soft and imbus tolerances with them not very strict. Be very careful with them, too much threadlocker or too strong one is as bad as no threadlocker - you might easily snap the bolt.
The top (rocker-side) mounting bolt dimensions are in the pic.
Unfortunately Jean recalled pic of bottom bolt before I was able to save it, but what I remember is:
  • nut OD is 8mm (M8) just like the top one
  • nut length is 32,5mm
  • bolt head OD is 15,8mm
  • head length is 3mm
  • screw is very likely M6 just like the top one
These bolts are custom made for SZZT which somehow explains their poor quality. Probably we could choose higher grade material if they were off the shelf/standardized ones instead of carved from a piece of soap.
spokémon
191
100
I already had the material at home recovered from old bikes, in any case the height of the spacer used is 7mm.
Wow! you needed 7mm spacers? Assuming Bafang oem chainline is 55mm (I have no idea about this), you now running 48mm chainline? Is that correct?
TBH, I just spaced mine out until it looked ok (eyeball method) without going too extreme.
8Grunf
36
122
Italia
I wanted to move the crown inwards as much as possible as I mainly use the largest pinions which are also the most delicate as they are made of aluminium.
I'm not saying it's the best solution for everyone, probably the most valid for my use.
spokémon
191
100
Yep, i totally understand. I had a similar problem with my chainline to the big cog
spokémon
191
100
Does anyone know standover height of a small frame with 29 wheels?
This is what I posted many pages ago. It's with 27.5" wheelset. So I think just add around 20mm to the measurment for 29"
similar discussion
Since then, I recently built a 29" front wheel for her without telling her. So it's currently running mullet.
During a ride, I asked her "how's the bike?" She didn't notice any difference and didn't complain (That's a good thing, I think)
Joshack92
Uk
similar discussion
My wife is 160cm, so should be all good! What size dropper did you get? Have you got any photos?
Does the mullet work ok? Was thinking of doing that but I’ll use the 29 wheels I’ve got kicking about first see how that goes!
She’s excited for it to come now, I’ve got all the parts just need a dropper post and it to turn up!
brbr
533
271
France
My wife is running a small with 27.5 front and rear, the bike is a bit small, 29 or mullet would be good. But she’s an absolute beginner so a smaller bike is ok.
I’ve installed a 150mm dropper but I think a 100 or 125 would be better
spokémon
191
100
The mullet runs well. I lowered the front travel to 150mm (it was 160mm with 27.5") so it didn't slack out too much.
Yes, try 29" first. See if it's comfortable for her. I think a 125mm dropper would be suitable.
lkdoido
35
22
Brasil
I was curious about the 150mm up front. I'm waiting for my size M with 29 wheels. My ride is flatter and a more agile bike for curves would be interesting. My current bike is XC.
What do you think?
martinvb
29
83
lyon
Hi guys, new here.
I'm really interested in building one of these frames but can't seem to get it in a reasonable timeframe.
By any chance, does anyone have an XL frameset to sell?
brbr
533
271
France
Hi guys, new here.
Lightcarbon delivers faster, I’ve experienced both and they are way faster
martinvb
29
83
lyon
I
I've seen those frames, they are really interesting, the lce930 or the lce971 but no xl sizes from them and measuring 196 size L is way too small...
martinvb
29
83
lyon
Hi, sorry to bother.
Anyone has experience buying from 4leaf? They have the cef50 frameset with motor and battery for a really good price with included shipping.
It's the first frameset i am thinking of buying and have probably too many questions.
Thank you
Imendiolea
14
[email protected]
Thank you
I bought from 4leaf. It took a long time to arrive. I placed the order in February and it arrived in July. I didn't have a tracking number and the waiting time was agonizing. Otherwise, everything went very well with Firon Woo, who helped me and customized the bike to my needs and was always attentive to my emails.
mike_kelly
994
839
US
I looked and no they don't. I guess a clever person could make one out of auto gasket material?
TCFlowClyde
1,392
913
Mesa, AZ
I sent out an email to Anna at GBK to see if any are available! Sure I could make one but blah...not accurately. Anyone looking for a side-hustle?😁
Well...this is why Bafang dealers frustrate me! Bafang has a minimum order quote (MOQ). Greenbikekit.com won't order until they get a sufficient minimum number of requests...which is unknown at this time🤬
So, basically, the gasket will likely tear and just use gasket repair sealant or cut your own.😈
TCFlowClyde
1,392
913
Mesa, AZ
Good news Bafangers of the M820 gasket acquisition seekers!🤩
Anna at GBK.com said she will stock gaskets when you're ready to regrease your drive unit. Unless you're really super lucky, the fragile gasket will likely break when it's cracked open. This happened to me with both of m600 motors too, but fortunately not for my much bigger (hence bigger and thicker gasket) on my M620.
So, email her at: [email protected] to encourage her and indicate that you'll eventually want an M820 gasket. The more that request, the higher probability that they'll stock it.💪
Here's the email correspondence: 👇
And my logic to get her to consider stocking them.👇😁
Disclaimer: the actual price may vary.💸
mike_kelly
994
839
US
You should post questions in the main active thread. This thread is just to record specifications.
I moved all my parts over from an Orbea Rise. I had a fox 34 factory and it works fine for me because I wanted a trail bike not an enduro bike. But the CEF50 was designed for a 160mm-170mm fork.
BenCatalan
27
10
Spain
good morning, a question regarding the chainring: it does come standrd with a 32T, but can I find different size aftermarket? Is it steel? Do we need any special proprietary tool to remove it?
576K
