Killswitch73
373
231
West Midlands
Yes that’s right
due around May/June or before
it’s very hush hush aswouldn’t tell me any more just that he told me not to buy a Orbea Rise and wait it out .
The person who did tell me this is also well known .
I just could not get anymore info .
could just be a red herring but he’s not been wrong yet .
Killswitch73
373
231
West Midlands
SL motor with software upgrade I hear..
Impossible to do it with software . It will be a new motor and maybe just maybe it can be switchable to the older frames of the SL . So it may look the same but the internals of different .
Who knows I only know they are bringing out a mid power bike .
JSQ
28
40
Finland
It would make no sense to not do it with a software upgrade. Otherwise It would mean that the Kenevo SL would be outdated after just one year since its release. I don't think Specialized would want to kill it so soon.
chamaruco
Inactive Member
Dec 28, 2020
393
329
Arezzo
i would find the news that i can update my firmware and upgrade the battery...when is christmas going to be this year?
Killswitch73
373
231
West Midlands
It won’t be software if it was software that would of done it ages ago . Creo was released 3 years ago with same motor . All I know is it’s mid powered around 50/60 with new battery .
Killswitch73
373
231
West Midlands
I doubt the SL is being maxed out at present, but more amps will make more heat and also put more stress on the nylon gears so it may not be up to it. Spesh are just going to use their Brose Levo motor and de-tune it 😆
It is maxed out . Or maxed out to the point that the battery is also culprit to the motor.
We will find out .
I also run the Levo SL and Kenevo SL Facebook page . The big one .
Killswitch73
373
231
West Midlands
is that right? does that mean the SL motor is already maxxed out for power output?
Well I’m 90% sure it is otherwise they would of done it when the Orbea rise was released . The Creo is now 3 years old with said motor. The way the motor works with the battery i don’t think it can be done . It will be a new motor and a little heavier maybe .
apac
1,326
1,173
S.Wales
We will find out .
I'm pretty sure that if you could change the controller inside the SL motor or even change it's set limits you would be able to get more power from the motor... but as I've said, it would make it less reliable and more amps would mean more heat and more torque on the nylon gears. but that would be DIY territory and not a manufacturing giant. The battery could easily give more amps if needed. The downfall would be a battery that last less time.
dobbyhasfriends
🌹Old Bloke 🎸
3,261
4,649
Llandovery, Wales
There was a video when the sls were released where @Rob Rides EMTB was talking to specialised SL designer (forgot his name) and he said new upgraded motors would fit current frames . But pretty sure that video was pulled from robs rides you tube channel .
I remember that.. updates would be backwards compatible. thats not really the case with what weve seen so far in regard to the mastermind though, thats not backward compatible.
There is no way the SL battery can pull double the amps needed to increase Torque of the motor to 60nm. It will be unstable and overheat .
usually depends on the BMS
ok so youre guessing a bit then.. it seems a reasonable guess but it would be great if the SL was 'upgradeable' to bring it in line with the rise. its the only reason ive not bought a KSL - the lower power.
apac
1,326
1,173
S.Wales
Jesus, how shit a cell did they use in the pack? The motor currently only pulls about 6 or 7 amps at peak power...... which will be for a very short time
dobbyhasfriends
🌹Old Bloke 🎸
3,261
4,649
Llandovery, Wales
I believe the 500's use the 18650, the 700's use the 21700 and no idea what the SL uses but it will be lithium and it will certainly be capable of higher discharge rate than that. although I guess that depends on the construction of the battery and the voltage it runs at etc.. I dont know these things so ill shut up now
apac
1,326
1,173
S.Wales
The SL pack is 320wh? It’s 48v and 6.6ah. Which means it must be 13 cells in series and 2 parallel…. Educated guess if using 18650 cells.
If each parallel cell is discharge rated for 5 amps then the pack should be able to discharge at 10 amps constant. Peak amp discharge could be nearly twice that.
I’d love to know what cells are inside
Doomanic
🛠️Wrecker🛠️
8,912
10,787
Sounds right to me, although I would have expected Spesh to use 3500mAh cells rather than 3300mAh for a little extra capacity with no weight penalty. I wonder if there's space in the frame for a pack made of 21700? That could be a 480Wh pack, but there would be a significant weight penalty.
Despite being a lazy fat knacker the lower power isn't the handicap I thought it would be and the light weight on the descents is worth the extra effort required on the climbs.
dobbyhasfriends
🌹Old Bloke 🎸
3,261
4,649
Llandovery, Wales
it wont do the climbs here mate, I can barely do them in turbo with every bit of power my legs have as well.
6,842
5,285
X35+ Hub Motor??:unsure::ROFLMAO::ROFLMAO:
Tbar
116
55
I’m very close to pulling the trigger on a KSL, so this info does not help my indecisiveness!
I just really can’t see Specialized doing this so soon after the KSL release unless it is a) a simple firmware update or b) a fully backwards compatible drop-in motor that could be offered as an upgrade for current SL owners.
Anything else would have a dramatic impact on KSL sales only a year into the (typically 3-year) product cycle and leave a real sour taste in the mouths of many owners.
EME
269
231
Zug
A PR scam?
Given their deliveries are so appalling, there is little value in announcing new models they wont deliver. It will only lead to more irritation ... they need to fix the problems they have not create new ones.
Mr-EPIC-3
195
125
USA, So Cal
The BH iLynx with it 150mm Fr/Rr, 65Nm, 540Wh and 16Kg (35.2lbs) vs Levo SL and Orbea Rise. I would like to see a compares review of all 3 of these eMTBs.
Harold
48
62
Brussels
BH wrongly communicated specs, purposely or not…
Best built is in fact 18.7kg. So it’s more 19kg than 16kg… However this bike seems promising.
For Spesh, I wonder if they would really bury the SL range so fast… I want evidence ;)
574K
