Status
Not open for further replies.
zorro77
318
476
Italy
I hope that Specialized does not create problems, I buy two turbo levo every year for different reasons, but the most important one is because I can use Blevo, otherwise I would not buy more specialized.
In my area there are many bikers who think so, Specialized I know you read, Please do not disappoint us !!
jonasdig
12
Norway
Sorry but it is the watch that stops to send the data or is the phone that doesn't receive the data?
The clock stops sending data. But I suspect that it's caused by that it dosen't get some kind of feedback from Blevo and turns off sending data to save power.
Goste
10
Lincolnshire
I've been playing around with Blevo, but I'm seeing quite a reduction in battery life. Getting only around 40 miles purely on eco. I'm trying to reset to the original settings so I can compare. I have a 2020 HT Levo with 400 battery.
After changing the settings and restarting the bike it seems the changes have taken effect. However if I use the 'Reload' button the changes revert back to the modified settings. Can someone explain exactly what 'reload' does please.
And any advise to get more out of the battery would be greatly appreciated. I'm currently running at 30/60/100
Benson
279
239
Hampshire UK
Sorry if this is an FAQ, is Blevo able to provide a post-ride breakdown of the power modes used during a ride? Ie, Eco for x%, Trail for y% and Turbo for z% etc?
kellermann
45
18
Sorry but I checked with a BLEvo tester with the same bike version and he didn't found any connection issue..
Could you send to [email protected] a video of the connection procedure? Maybe I can understand the issue..
Thanks.
It seems, that it was an issue with the may-21 update of Android 11. Last night, i installed the june-21 update and since then, blevo functions well again. I hope, the next security-updates of Android 11 will not change this.
KrisFl
17
8
Leefdaal
After more than five months of testing, I am pleased to announce the full integration of the new Levociraptor Generation 2 into BLEvo.
The new Levociraptor (called Gen2) integrates a Bluetooth module for connection with the SmartPhone. In addition to the unlocking of the speed (for Brose and SL motor) that can be customized from the phone, it also allows you to detect the ambient temperature, the atmospheric pressure to have the altitude measurement with extreme precision.
The joint development team has made it possible to achieve important improvements in SmartPower management in BLEvo as BLEvo will receive data directly from the Levociraptor without waiting for the delays introduced by the TCU. This integration with the SmartPower allows an improvement in responsiveness and fluidity in the delivery of engine power.
Through the BLEvo interface it is possible to instantly remove the speed release or send the position in the event of an accident, these two functions can be activated automatically in the event of an accident.
The interface with the Levociraptor Gen2 is available to all BLEvo users in free mode. Versions 3.9.0 for Android and 3.7.0 for iOS have been released and are available in the stores.
For more information on the product visit the website
The Levociraptor Gen2 will be available in a couple of weeks.
You can preorder it.
@PaoloBLEvo I have now used Blevo for 3 years on my Levo 2018. As I have a Creo SL as well, I would like to buy the Levociraptor gen2. Is it possible with Blevo to adjust to speed to any km/h you want? So I would like a bit more than 28 kmh, but not the 45 of the next setting of the levociraptor. Can I adjust to 35kmh? Thanks!
Jersey Skier
150
64
NJ, USA
Are you able to use Blevo with your Creo? Here it the US the Creo has a 28mph max speed. However for some reason Blevo always resets the max speed to 16 mph no matter what I try. Pretty much gave up trying after numerous failed attempts.
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
The reload button forces the reload of all the parameters from the bike.. for example, if you change the setting with Mission Control, you should press the button reload before change something with BLEvo...
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
Yes.. in the statistics part you have these information..
ie
Assistance average: 34.2%
- ECO: 10.4%
- TRAIL: 23.2%
- TURBO: 100.0%
Ride Time:
- Start time: mer, 09 giu 2021 14:52:48 CEST
- Stop time: mer, 09 giu 2021 18:16:18 CEST
- Elapsed time:2:04:43
- OFF: 0:08:42 (7.0%)
- ECO: 0:12:28 (10.0%)
- TRAIL: 1:29:11 (71.5%)
- TURBO: 0:14:21 (11.5%)
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
Thanks a lot for the feedback.
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
Yes, you should buy Levociraptor Gen2 for this.. BLEvo can handle only the Levociraptor configuration and cannot change the speed limit without Levociraptor..
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
I just released BLEvo version 3.9.6 for Android.
In this new version I have added the link configuration for maps. In this way everyone can put the maps they want as long as they are compatible with the format specified by open street map.
Here you can see some examples of the links
OpenStreetMap Wiki wiki.openstreetmap.org
Here is the news list:
- Added maps with customizable links
- Correct ascent calculation with DEM
- Fixed display of the tour map with invalid values
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
fraatti
100
41
Finland
We had first ride with new custom map setting yesterday. Everything worked well. I have missed this feature over year. Thank you for that. (y)
Another bike suffered from Blevo hangup with two last rides. It has levocirator v2 installed. Another didn´t hang and it didn´t have L V2. Maybe its related to levocirator v2. Could log files help with tracing bug?
fraatti
100
41
Finland
How Blevo map cache works? Is it caching just downloaded tiles and deletes everything else? Or maybe caches some certain amount of data so you can cache multiple places at same time? I am asking this because tile server is littlebit slow and it would be best to use data little as possible.
KrisFl
17
8
Leefdaal
Thanks @PaoloBLEvo ! If I read the manual on the website of 2wheelsempire, the selector of the Velociraptor is always on 4 and the speed can be set with the multiplier on Blevo.
So, just to be sure:
- I install the Velociraptor
- I connect Blevo to the Velociraptor
- I set the multiplier to 1,2
- The speed limit for support will be 34,8 km/h (29 x 1,2)
Is this correct? Can you please confirm?
Thanks again...
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
Yes.. there is a cache mechanism.. But when you change the link the cache is removed..
If you press the download button, all the tiles you are seeing will be downloaded...
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
Could you contact me to [email protected] and we will try to solve the issue?
PaoloBLEvo
Trader
Jun 13, 2018
1,457
1,191
Varese
Thanks again...
If you set the Levociraptor to 4, you should set the speed multiplier to x2.
hM7wtMiA5-Eyp59kzWRG-Dr2tWm8XTJNzS49UjZIuOU88ni5Z_mTnwAAoIiEeYWFTVH9ZV4yVVMN7iHdu2lZtHnBS5JoaILDveBevwHHS26zKWQVYBDBOcM9XA4Zz4bAFiteqLw
KrisFl
17
8
Leefdaal
@PaoloBLEvo Thanks for the fast answer, but not an answer to my question. According to 2wheelsempire, the manufacturer of the Levociraptor, you can not change the selector on the Levociraptor GEN2 - it is always on 4. See below the picture from the communication. This seems very strange to me.
I do not want my speed limit at 57,5km/h. I want it at +/- 35km/h. Is this possible?
Goste
10
Lincolnshire
Yes I use it with mine...
somewhere in here its confirmed...
Couchy
143
156
Nottingham
Thanks ?
robespana
23
9
Spain
It seems the setting in posistion 4 is just a PRE-setting, you CAN change it !
I have exact the same question, would only want it to go a bit over 30km/h to not drain the battery in ECO
but still have some assist.
Status
571K
