Ok... Il will check with my tester.. sorry for the issue..A test with eGenesis also was successfull, so a hardware problem is not very probably.
I tested the maps with not 3D map and it works even if I'm not in Finland..
This link works..
it return a white picture and not a server error..
Could you check why the link
https://tilestrata.trailmap.fi/d3-mtbmap-cache/3d/13/4296/2919.png
is not working?
I will implement withWierd, every other map is returnin the white tile.
I will ask from server developer what is going on.
Maybe is has something to do with tile location because this works. I have no idea how these tiles are named.
https://tilestrata.trailmap.fi/d3-mtbmap-cache/3d/13/4296/[email protected]
it works..
it works..
You mean that you would like to addI heard from map developer that mapserver usage is not allowed to commercial applications. However "user specific" mapserver is ok. So maybe feature should be user definable server? Then every user can specify whatever maps they like? Looks like that they are compatible with software you used.
I think you have Android 11..
Please go to the authorization of the app and remove it.. After restart BLEvo and answer yes to all the request of permissions..
Let me know..
https://tilestrata.trailmap.fi/d3-mtbmap-cache/3d/{z}/{x}/{y}@2x.png
somewhere in the BLEvo app?
This is allowed but if the value is hardcoded is not allowed? Very strange..
https://docs.locusmap.eu/doku.php?id=manual:advanced:customization:online_maps
Just want to chime in that Trailmap integration would be a HUGE for Finland users!
Please check also the battery optimization for BLEvo.. you should remove all the optimization..Hello Pablo,
I do run android 11 ( on samsung galaxy s10).
I re-installed blevo and gave it all permissions ( and always on in back ground). I had several runs. Sometimes it works, mostly not, it does not give a map, or it gives a map but says: "no csv file found".
When I want to see a graph. I get message: That I need to enable the csv file creation. But I can not find this option in Blevo.
What can I do?
I will add the possibility to enter a custom link..Yes, exactly.
Restriction for commercial use says something like this (I used google translate)
The use of the map services provided by Trailmap is permitted for private non-commercial use and reasonably, meaning that the number of bricks loaded is such that it does not interfere with the operation of the service. This is not a problem with normal map use. For other uses, first contact support (miuku) trailmap.fi.
Here is list of some free tile servers.
Tile servers - OpenStreetMap Wiki
wiki.openstreetmap.org
It seem that some of the tile servers want query tiles littlebit different way. Some of them need $-sign before parameter. I think that need to take into consideration if there is possible to enter own address in some settings.
Some example with $-sign: http://b.tile.openstreetmap.fr/hot/${z}/${x}/${y}.png
It is also described here.
https://translate.google.com/transl...fi/blog/trailmap-kartat-muissa-sovelluksissa/
Locus maps setting file look like this
https://docs.locusmap.eu/doku.php?id=manual:advanced:customization:eek:nline_maps
I don't know how to post this link so it is working.Code:https://docs.locusmap.eu/doku.php?id=manual:advanced:customization:online_maps
edit. fixed links, forum software broke them.
So the responsibility is demanded to the user..
Do you know will the offline map download work with custom link, example using the trailmap?
It think it should work exactly same way as it works now because just server changes. I don´t know does it make any difference when tile size is 512x512 or 256x256. If some area need 100 tiles with 256x256 it would need just 25 tiles with 512x512...Maybe software handle this automatically....
Sorry but I checked with a BLEvo tester with the same bike version and he didn't found any connection issue..I have tested it with my iphone and the last ios version of blevo, and all functions fine.
So i guess, it could be a problem with the last android 11 update for my samsung s20.
On my samsung, blevo finds my bike, sees the battery, but could not read any information.
Deinstallation, deleting all data of the app has no effect.
In Android 11 there are a lot of battery optimization configuration... Please check again, because this is the same issue with another BLEvo's user, and he found an optimization for BLEvo active.Battery optimization is not on.
The message should be "without the bike connected".. not the motor..things changed again (related to my posts from May 19. and 21.).
Yesterday I got the blue dot after I switched on the bike. But therefore, after starting a tour in BLevo, I got the message "do you want to start the tour without motor?". After "cancel" and tour start everything worked. This is only a minor bug. However, either I do not get the blue dot for connenction or I get the warning message.
You should wait blue dot in the home page AND, after open the bike monitor, you should wait green dot or ? for the bike..
This sequence should work always..
Hi everyone newbie to EMTB, at 50 decided I need to move more , so went ahead and bought turbo levo comp, added the Levociraptor v2 for good measure , but having difficulty with the smart setting , tried heart rate only but bike seems to give full power assistance no matter the heart rate im sure I’m missing something so any guidance would be greatly appreciated , for the settings … many thanks in advance .
Sorted, just needed to read a good few more pages on here ….Hi everyone newbie to EMTB, at 50 decided I need to move more , so went ahead and bought turbo levo comp, added the Levociraptor v2 for good measure , but having difficulty with the smart setting , tried heart rate only but bike seems to give full power assistance no matter the heart rate im sure I’m missing something so any guidance would be greatly appreciated , for the settings … many thanks in advance .
Would be perfect app if you could make trailmap work. Is it possible add own map all-ready?
