Levo SL Gen 1 Official Levo SL Thread
TomH79
322
304
Finland
So what ranges arw people getting with sl levo, without range extender?Yesterday did a ride with my 2020 levo comp, bit over 100km and battery left around 30%. mostly ride with eco 15/30, little turbo 100/100.
Really been thinking of an sl model but need to do some serious testing before any desicions.
Waynetta
193
179
Plymouth Devon
Furthest so far is 41miles and just over 4000ft climbing. I had 19%battery left when I got home. Ride time was over 4 hours.
I used turbo a few times on the steeper sections but mostly eco set at 35/35. I’ve come Home feeling much worse after 30 miles on a carbon stumpy ive had for 4 years. I’ve done 30 miles on the SL and hardly broken into a sweat with 2000ft climbing. ??
Vin829
107
42
California, USA
I go by elevation not miles because where I ride is steep. I get 2-2.3k feet out of each extender and about 4.5k feet out of the bikes main battery. Using trail 60/60 most of the time
Bencab
190
483
California
Rode solo again today. Ride time is about 6.5 hours; about 53 miles and 7,300 ft of elevation. All eco until the last 3 miles where I used trail. I used 2 extenders. The first extender lasted for about 10.72 miles and 2,600 ft of elevation. After this ride, I have 23% left. For comparison purposes, I did the same ride with my pivot shuttle using 2 batteries but only managed 45 miles and 6,600 ft of elevation. The SL is very efficient and the weight really is noticeable when climbing steeps.
boBE
415
363
FL
Been riding my Levo SL Comp for about a month, my most ambitious ride so far was 32 miles. The ride is Florida flat, elevation change of less than 16 feet except for the bridge over the ICW which is a whopping 75'. Most of the ride was in Eco (set for 35/45) except for the bridge where I used Turbo for the minute or so it took to climb the grade (maybe 12%). The battery was down to about half so I can probably expect 50-60 miles on a charge.
The first time I get stuck out of power will be the day I order the battery extender but I doubt I will ever need it.
My SL weighs about 45 lb with all the crap I carry (tools, tube, water bottle) and it lost maybe 1-2 lb when I switched to 27.5" wheels. They feel much better than the 29s plus I went with Continental RaceKings since I ride mostly dry hardpack.
McInner1
229
174
Austria
All your data about achieved duration and altitude meters and the remaining battery level are not very meaningful, if you do not also indicate the personal contribution (kCal/kJoule)!
TomH79
322
304
Finland
ImSundee
328
316
Oxford
First part of upgrades started to arrive today, Got some Zee brakes to replace the terrible Glides. Waiting for the front to arrive then I'll get them installed hopefully before the weekend.
jemen
317
379
Austria
Can you use the cable routing from the guide?
Killswitch73
373
231
West Midlands
Can you get full compression out of that with the range extender?
I’d like to know if anyone has tried a Rockshox Super Deluxe Ultimate, and if it fits?
I want to know this too as ive got coil ultimate on my stumpy and now im thinking this wont fit .. im about to order my comp carbon any day now .. this would pee my right off if the extender wont fit .
Uhrensohn
Bayern
Unfortunately I am broke now since I also ordered a Levo SL Carbon Comp.
The only thing I didn't like about it was that I am used to switch 2 gears at once with Shimano but hey, lets see if I can get used to it :)
Sorry if this was answered before, but I heard you can switch out the cassette for an X01 to save some weight, do I JUST need this cassette or another part as well? Thank you.
Kpmnd85
45
35
Austin, TX
You need to change the free hub. You can order this through your specialized dealer. The Company Carbon freehub is a Shimano HG
Uhrensohn
Bayern
Yes, im running NX everything with X01 cassette (although DT Swiss wheels with XD Driver). You just need to appropriate driver for the stock wheels as listed (y)
btw would a shimano XTR cassette also fit, then I do not need a driver?
which dt swiss wheels are you running if I may ask?
571K
