un..inc
127
111
Okay, if that's the case, I'll also delay my order a little until it's all been put in and tested.
I already have a super deluxe ultimate at home, but coil is worth a try, especially on an e-bike.
UDH is very important to me, so I'm happy to wait a few more weeks...
Does anyone have any news about the price and availability of the carbon battery cover?
temon10
676
565
Malang, Indonesia
are u sure few more weeks for their new triangle?
un..inc
127
111
No, of course I'm not.
"A few" is also a matter of definition. It could be 6-8-10-12. I don't think they would communicate it if the construction wasn't already relatively advanced.
I can wait and am happy about every improvement.
spokémon
191
100
It's going to take time.
UDH - chainstay modification
lower shock mount reposition, front frame modification - I would imagine they also have to look at the effects on suspension?
carbon battery case: my conversation on 2023-08-02
"3D print model will come back this week, then will try assembling, when all are ok, will open carbon mold, and it needs longer time."
patdam
908
602
france
It makes no sense.
I always thought the displays were auto-voltage-sensing (is that a thing?) or am I wrong?
sure, but may be previous versions can't manage 48V ? Only supposition following information collected (guy with previous rev of HMI who don't fuctioning with 48V, supplier who change proposal to DPC245 3.0 when battery power supply changed to 48V). Not a "truth true"
stuff
166
281
Spain
I suggested moving the shock mount, but Linda told me that she’s not sure engineers will do it since it’s modifying the front mould and that’s quite expensive.
UDH is almost ready as she told me, i’ll order that piece to replace my normal hanger.
Also, bare in mind to order the frame with cable holes to avoid using the headset ICR
un..inc
127
111
I'm still torn about the headset.
It's actually quite cool not to have any visible cables on the frame, especially if you use axs.
On the other hand, it's a lot of work and it sucks when it doesn't fit 100%.
It's also annoying that you have to buy a new headset because the one that comes with it isn't waterproof.
In any case, I have agreed on a suitable colour with Linda. It could be cool.
I also can't imagine that they'll change anything else on the front triangle just because of a few guys who would like to ride coil. The kinematics would also change and that would be a huge ef
fort.
spokémon
191
100
I guess we'll see when I get mine. she said she'll send it 😉 it'll really suck lemons if it only works on 48v
Lehr
77
183
China
stickers diy
Lehr
77
183
China
The motor makes a loud noise when going downhill, like there is a steel ball jiggling in the motor, do you guys have any of those?The seller replaced the motor with a brand new one for me, still the same problem
Lehr
77
183
China
It's like the chain is shaking and constantly pulling on the clutch.There are 4 videos in the zip
  • M820 noise video.zip
JJ-NOR
12
Norway
If i could ask, do someone have spec list, for parts that fit this frame?
I would like to start and buy the correct parts for CEF50 frame :)
temon10
676
565
Malang, Indonesia
Fork 150-160mm, rearshock 210x52.5/210x50 (air only), wheelset can be all 29er or mullet with 12x148 freehub. Other part U can choose what U need.
Myalteregohamish
294
240
Vancouver, WA
There’s a clank similar to shimano, that’s normal though. Are you sure it’s not the cables inside the down tube clanking against the wall of the frame?
Lehr
77
183
China
Nothing to do with suspension, cables, rear derailleur, if you remove the chain (clutch doesn't work) you'll notice it's quiet
561K
