Thanks I just looked on their website I couldnt find them might have to make a callHi there - if you are still looking for the rubber guides go to moruya bicycles online. I got a spare set recently.
01. FRAME | eONE-FS CFA II; MAT carbon; 150 STR; 29/27.5" WHS; 148x12 AST; intube; |
02. SIZES | M-L-XL |
03. FORK | FOX 38 Elite eMTB+ Air; 160 STR; Tapered; 51mm fork offset |
04. REAR SHOCK | FOX Float DPX2 Elite; platform |
05. DRIVE UNIT | Shimano STePS |
06. BATTERY | Shimano STePS |
07. BATTERY CHARGER | Shimano EC-E8004; 4A |
08. DISPLAY | Shimano STePS |
09. SWITCH | Shimano STePS |
10. REAR DERAILLEUR | Shimano XT RDM8100 Shadow+ 12 |
11. SHIFTERS | Shimano XT M8100 12 |
12. BRAKE-FRONT | Shimano XT; 4 piston |
13. BRAKE-REAR | Shimano XT; 4 piston |
14. ROTOR-FRONT | Shimano RT-MT900; 203 mm |
15. ROTOR-REAR | Shimano RT-EM910; 203 mm |
16. CHAINRING | Shimano CRE80-12-B; 34 Tooth |
17. CRANK | Shimano FCEM900; 165 mm all sizes; hollow |
18. CHAIN | CNM8100 |
19. CASSETTE | Shimano M8100; 10-51 ATC; 12 speed |
20. PEDALS | VP; VPE-527 |
21. HANDLEBAR | MERIDA Expert eTR; 780 Wide; 20 Rise |
22. HANDLEBAR STEM | MERIDA EXPERT eTRII; MAT aluminium; 35 DSH; 0 ASD |
23. STEM LENGTH | 40 mm all sizes |
24. SEAT POST | MERIDA EXPERT TR; 30.9 DSP; 0 SSB; XS 125 SPT - S/M 150 SPT - L/XL 170 SPT |
25. SADDLE | MERIDA Expert CC; V-mount |
26. HUB-FRONT | DT Swiss |
27. HUB-REAR | DT Swiss |
28. AXLE-REAR | MERIDA EXPERT TR; including removeable lever, 6/4mm allen key |
29. RIMS | DT Swiss Spline HX1501 ONE 30 boost; 110x15 WHF; 148x12 WHR; 30 IWR; Centerlock; microspline; MAT aluminium; Tubeless ready (tubeless tape and valves included) |
30. TYRE-FRONT | Maxxis Assegai; 29x2.5 "; fold; 3C MaxxGrip DD |
31. TYRE-REAR | MINION DHR II DD; 27.5x2.6 "; wire bead; 3C DD |
32. MUDGUARD | C093-02F + C093-02R |
33. LIGHT FRONT | E-BIKE POWER STVZO E115, reverse MERIDA Custom Mount |
34. LIGHT REAR | LED FEMTO USB REAR STVZO |
35. OTHER | MERIDA Multitool with saddlebox |
03. FORK | FOX 38 Factory eMTB+; Air; 160 STR; Tapered; 51mm fork offset |
04. REAR SHOCK | FOX Factory Float X2; platform |
10. REAR DERAILLEUR | Shimano XTR Shadow+ |
11. SHIFTERS | Shimano XTR M9100 |
12. BRAKE-FRONT | Shimano XTR; 4 piston |
13. BRAKE-REAR | Shimano XTR; 4 piston |
18. CHAIN | CNM9100 |
19. CASSETTE | Shimano M9100; 10-51 ATC; 12 speed |
24. SEAT POST | SP REVERB AXS; 30.9 DSP; 0 SSB; XS 125 SPT - S/M 150 SPT - L/XL 170 SPT |
29. RIMS | DT Swiss Spline HXC1250 spline 30 boost; 110x15 WHF; 148x12 WHR; 30 IWR; Centerlock; microspline; MAT carbon; Tubeless ready (tubeless tape and valves included) |
Some specs of the new 2021 model 9k and 10 k
EP8 /630whHi where did you get this from? Interesting it does not mention the battery size.
EP8 /630wh
Is yours a large? Seems to be common, I'm keeping a close eye on mine
Lucky boy.... I'm out most Saturday mornings but that's about it for me. The joys of working full-time and having a family haha. Would be nice to live closer to a trail centre, i could ride before or after work... It's a strong consideration to where i will buy a house next year ?yep, I don't foresee many issues as this is a wide spread issue. More the time I'll be off the bike. I ride 3-4 times a week and this is going to kill me mentally.
Just my luck to crack one during a worldwide pandemic lol.
I have a merida e140 LTD (aluminium) 2020 model. It isn't a year old and has about 1500km. I just discovered the bottom shock mount has some play. Would you consider this a warranty issue? The bike hasn't had hard use judging by my low suspension pressures and tyre pressures and I rarely bottom out with those low pressures.
Thanks horspwr. I wrongfully jumped to a conclusion. I don't normally have things come loose on me - it was loose! Bit of a concern. I had it apart about 3 months ago to remove the tokens - cleaned, greased and torqued. At this point, I think I'll clean the threads of grease and use some contact cement as a thread locker. I can imagine how it happens with that pivot point - much up and down and some rotational force.I certainly would take it back and get it warrantied.
Is this through 99 Bikes? If thats the case we will be a week later perhaps in NZ...also means that Shimano are confident on the changes to the EP8Got to wait till December 8 for our E160 9000 and the girlfriends 8000![]()
Yeah that's through 99 Bikes. Seemed to be pretty firm too as in won't take any longer.Is this through 99 Bikes? If thats the case we will be a week later perhaps in NZ...also means that Shimano are confident on the changes to the EP8
cheers - good to know. I have been asking if the 10K still ships with another battery like last year.. almost worth the extra if thats the case. But I suspect notYeah that's through 99 Bikes. Seemed to be pretty firm too as in won't take any longer.
How does it compare to the LTD (aluminium) model? Aluminium model is cheaper and easier to live with. Personally, if I was you and you still have your clockwork bike, I'd chill. It's all their way right now; it won't be long till that changes.Just been told by my Adelaide LBS that the 2021 e160 500 model that I had a deposit on will not be proceeding as an available model
Not sure if this is Aus only or world wide
Options are to go to the cheaper 300 or more expensive 700
Lower specs on the 300 aren't desirable so trying to get Merida Aus (Advance Traders) to reduce the price on the 700
Still saying December delivery though
Decisions, decisions !
We bought a 9000 and an 8000 and I told them to take a grand off each and I was happy. Called my local shop and told them I would pay a deposit now over the phone if they could do that and after a minute of being on hold they said OK let's do it.What sort of discounts are peeps getting in Au? Looking at the E160 9000 (2021)
