New 2025 Wild
KKe
Finland
Any info or rumor when the 2025 Wild prices and specs are launched?
What will be new? Bosch Gen5?
KKe
Finland
And probably 600Wh battery? As the new 800Wh will be longer than current 750Wh.
600Wh would be ok because weight saving, on current model I would choose 625 battery anyway.
jbrown15
789
650
Chilliwack, Canada
Truthfully I’m not sure about the batteries yet. I think we’ll know more about the 2025 bike in the coming weeks.
sluette
95
93
Deutschland
That would make me skeptical of the light eMTB market. A 600Wh battery and a weight around 20kg would suit my needs perfectly.
killerade
28
11
Slovenia
pretty sure I read both the new batteries have the same form factor (so manf. can swap between the at assembly easily)
I believe the 800Wh battery is slightly wider...
Rob Rides EMTB - Bosch Launch New Gen5 Motor, Huge Update!! [gWA0HDZGkX4 - 2018x1135 - 9m59s] ...png Rob Rides EMTB - Bosch Launch New Gen5 Motor, Huge Update!! [gWA0HDZGkX4 - 2018x1135 - 9m54s] ...png bosch_abc (1).png
  • Like
Reactions: KKe
cykelk
107
141
Cascadia
I’m sure you could get the new carbon Wild with the new 600wh battery down to 46-47lbs ready to ride with solid components.
This is my expectation and I may be a buyer if it comes true. Other dominoes that need to fall for a real SL killer would be drag and motor whine.
Such a shame... So only the top version comes with T-Type, and the rest is fitted with Shimano...
I was hoping to see MX wheels. I noticed many of the builds also still spec the old motor and battery, so not sure how accurate the kit details are.
jbrown15
789
650
Chilliwack, Canada
I don’t know about motor whine, but the new system is supposedly much quieter with hardly any rattling.
There will be an available link to let you run a mullet setup, but as far as I know the bikes will come as a full 29er.
KKe
Finland
There is also ST models with 150mm fork, ST=short travel? Unfortunately only alu versions, and quite low specs, RS Psylo and Fox AWL forks. With carbon frame and 600Wh battery the ST could be my choice.
sluette
95
93
Deutschland
really nice bike. I would go for the M-Team with 600Wh accu und Fox Transfer Post. But what a shame, only Shimano drivetrain available…
Chicane
360
309
SoCal
With the 750 battery still being an option, does this mean that the new batteries are cross compatible, but only with the 600, as the 800 is too fat.? I read somewhere that they weren't.
b33k34
257
98
if its using the old batteries the it feels like an 0.5 revision - weight presumably be the same as last year bar 100g for the motor? the new 800 battery would have shaved of another 500g
would like to see a real world weight for this vs the Rise now
whitymon
126
62
Europe
I did not found the 800 so, but there is a bundled mullet option!
Might be wrong but it still reference the bosch motor as BDU3840, which is the gen4 if I am not mistaken.
Edit: must be the new one looking at the fixation of the motor.
whitymon
126
62
Europe
Mullet or straight 29 seems to be through a specific parts, I wonder if it would be possible to buy the parts if you want to change depending on what you do.
Still 170/170 is really good in my opinion, the WILD M-TEAM in carbon raw / red is gorgeous.
jbrown15
789
650
Chilliwack, Canada
Your Orbea dealer will be able to order the links at some point, they list both the mullet link and the 29er link in the spare parts section.
TurdFarmer
31
29
Ikr, looked first thing this morning for pricing. Transmission on the LTD only sure is a kick in the balls.
The bikes so far have been a bit of a let down expect for the Crestline. Guess I'll be waiting another year or two for the new Yeti or Bullit before I purchase a new bike.
jbrown15
789
650
Chilliwack, Canada
Two things I was hoping to see with the 2025 Wild, no more headset cable routing and I was really hoping they would use the 800wh battery.
549K
