Markhor Kunlun M510 - 190mm - Super Enduro Build-Log
zorro77
320
486
Italy
What do you think of these answers? I was thinking S3...and I understood that 29 behind wasn't possible
- I'm 174 cm can I use S3?
My suggest is use S2 .is better .
- is there a different rear frame to use 29 rear?
can use .and rear wheel all can change 27.5 and 29inch .
Speaking of autonomy:
If you go slow using little motor and battery, how much D+ can you do at most? with the Levo and 700 battery I reach 2000D+ I would like to understand with this 720
zorro77
320
486
Italy
+ Leva contagocce ZTTo
+ Cuffia e distanziali ZTTo
Trasmissione
+ Trasmissione ebike Shimano M5130 linkglide con catena KMC e10 ept
+ Tenditore ISCG05 DH
Okay for the spacers, but the headset is NOT included?
Is Shimano linkglide compatible with UDH?
kaaskopf
177
227
Berlin
please keep it english,
-29" rear for now not possible
- usage of battery depends on to many factors to say anything about that
for sizing check the geo table. on the bottom it shows riding length
kaaskopf
177
227
Berlin
yeah shifting works fine. UDH is just the hanger part. now its universal its easy to get replacements. if you would remove the hanger you could install a direct mount from sram i guess but i did not try that.
headset was included yes, but got one anyway
maasy
12
40
I just got back from a 4 day mounting biking holiday at Narooma and Eden trails in Australia, putting the Kunlun though some punishment... from fast flow trails to double black janky lines to big jumps lines I've put the bike it though it all and it hasn't missed a beat. My bike is set up with an 180mm fox 38 and a fox x2 at 175mm rear which is perfect for my riding, I'm 5 11" tall on an S3 frame size and can fit a oneup 210mm dropper, the suspension has an sensitive bottomless feel about it no harsh bottom outs good support in berms, I find you need to weight the front wheel in switch backs when climbing but other than that its a pretty competent climber . bike weights 24kg but rides a lot lighter and is quite nimble at speed easy to change direction, it's a long beast at 1300mm and very stable at speed but the trade off with the longish chain stays is a little more effort to manual the front up, bafang m510 motor has been good, I've only ridden the shimano ep8 to compare it to. but the bafang is a lot more powerful at 95nm and feels smooth, has a lot of adjustment in the app with 4 parameters adjustable, but lacks the adjustment of the torque sensor sensitively in lower power modes, I have ordered a k1 programing tool to fix this issue ? it comes with a 48v 720wh battery which when ran in s+ mode lasts 35 to 45km 1000+ elevation on most of my rides away, you could get a lot more km in lower power modes... haven't in counted any issues with the bike as yet ? broke the plastic motor cover on a rock so order a few spare's when ordering your frame and Loctite the suspension pivot bolts as had one come loose and unscrewed, hope this helps...
I'm pretty happy with my purchase get ordering 👍
zorro77
320
486
Italy
38 but you need 36
On my Levo I use 32 in front and 11-46 in the rear, I go slow uphill I like to pedal. I'm not interested in unlocking speed and power. I think 32 can also be good on this bike or am I missing something?
kaaskopf
177
227
Berlin
depends on the engine
the m510 likes the 34 or 36
my max speed is already low at 32km
i use my bike in mainly eco mode and cadance of around 80-100
zorro77
320
486
Italy
I've now ordered it with 32T, we'll see after some tests, I've seen that they are cheap on Aliexpress... how long does it take to recharge the battery?
azure
47
15
PL
battery size is 500x75x60 mm
bleeding of the brakes was the easiest i ever did! well done TRP! took me 3 min each
also adjusted the shifter and installed the dropper
i threw all the parts on the bike quickly and weigh it. this i was the most curious at.
because of bad weather i didnt testride it yet or took any pics...
still acceptable weight i think, mind it is basicly a DH bike at this point
my E10 with smashpot and same rims was heavier in the end at 26.9kg
what do you guys think?
Identical weight to my Markhor Rocket bike, where I didn't take care about kg's...
kaaskopf
177
227
Berlin
so after 500km im still happy
some things i found
DH is absolute king with this bike.. it handles anything
climbing is solid but it requires some getting used to due to the 63.5* headangle
tight switchbacks feels kinda weird because of 1300mm wheelbase but still doable but it needs more preparing and focus.
also the bike developed a kindof clunking sound from the toptube everytime i hit some bumpy piece of trail. my guess was that its the cables and connectors from the toptube display. as there are many cables and extra connectors
i taped them all with foam tube slid in half and stuffed them in the toptube, after this mod the frame is fully silent
kaaskopf
177
227
Berlin
noname aliexpress
the problem was in the chainring spider supplied by bafang. it was the wrong version that didnt allow any chainguard
i milled some material off the back and now it works well
zorro77
320
486
Italy
I foud it:
so to help future readers, I ordered this, I will update when it arrives:
PS in theory tomorrow Sam will send me a photo of the frame ready for shipping 🤩
8Grunf
36
122
Italia
L'ho trovato:
https://www.emtbforums.com/threads/bafang-m510.26180/post-548801
quindi per aiutare i futuri lettori, ho ordinato questo, aggiornerò quando arriverà:
https://it.aliexpress.com/item/1005003640002084.html
PS in teoria domani Sam mi manderà una foto del telaio pronto per la spedizione🤩
zorro77
320
486
Italy
@kaaskopf What are these holes for?
PS do you remember how many links your chain has? I would have a new 116 liks but I don't know if it's short
8Grunf
36
122
Italia
ordered a chainring spider of greenbikekit to see if that fixes my chainguide fitment issue
in the meantime new parts came in
evosid crankset 165
34T chainring
dmr v11 pedals
Hybridiser bb bracket 'motor mount'
seems to make sense for those days i just do uplifts in the Alps, it was cheap enough to try it anyways
Hi Kaaskopf,
I have a question, do you know if Evosid cranks can be mounted on the Bafang M560?
I have doubts about it...
577K
