Strive:ON problems
jxrx
100
37
Zürich
So I wouldn't open a new thread, let me ask here. I have a chance to buy Strive:ON for ok price, in a ok condition. Is it fine as a first ebike, or should I aim for some other model/manufacturer?
My first ebike and I have an enduro which I ride hard and have raced. I feel fine as many bikes have an Achilles heel of some sort. Never is everything perfect and everyone perfectly happy. So go for it! I did 😁
Jona
103
44
Belgium
I don’t think it’s going to be the new one, I have been told in the beginning of 2024 for “the fix” 🤷‍♂️
this is what i recieved, only the cover, not the latch itself:
My expirience with Canyon service Belgium has been exellent up to now. I assume that above shipping went wrong in Germany, where it was shipped from. Anyway quit annoying. luckely my temp solution still works.
el.guillyt
46
16
Spain
Glad your service support works properly, I've sent a service request almost 2 weeks ago, still nothing back from canyon, I did get a feedback request survey email for such service ticket, of course I've valued as 0 stars....I'm never buying a canyon again
Mario Antony
231
183
Portugal
Jonas, the cover won't do anything. Canyon messed up on the delivery...
PS: the package, should contain:
1 Latch + 2 Torkx bolts
1 Cover + 2 Torkx bolts
Use all solutions you can, otherwise, bike will be stopped due to this latch design flop!
Jona
103
44
Belgium
I'm sorry i was not clear. i'm aware that what I received is not what i need. this cover is the only part i did not need to replace . What i wanted to say is that i don't think the error of this wrong shipping is caused by Belgian service center but at Canyon shipping/warehouse at gemany.
FYI, to fix it temporary, I did these updates:
  1. add plastic under the pastic latch (repair the issue if broken lips)
  2. add a thin plastic part under the metal hook (avoiding play, in general)
Mario Antony
231
183
Portugal
That will take play, but will force all the time.
The mod you should be using is the ZIPmod.
Jona
103
44
Belgium
As mention before, canyon Belgium service is great, they already replied.
this is the reply (translated with google)
We are still working on a definitive solution, but because Bosch cannot offer a definitive solution in the short term, our own Canyon engineers have also started developing an adjustment. But this will also take some time.
That is why we will send you a new part with a temporary solution, which according to our initial tests is very reliable. This part will be shipped via UPS,
So I'm still happy with the service of Belgian service team.
to be honnest, i'm so happy with the Stive:ON , i would still buy it , regardless of the issue. I really love how it rides.
Mario Antony
231
183
Portugal
Jonas, IF, Canyon would have develop THE SOLUTION, Canyon would contact ALL CUSTOMERS.
Stay well
Jona
103
44
Belgium
And they will ones they have it, I assume.
it seems fair to send the temporary solution only to the customers with issues, for the time beeing.
Mario Antony
231
183
Portugal
Jonas... what temporary solution? They're replacing broken parts with the same pn (part number).
Get your head out of the sand, please.
CrispyDesigns
198
173
I fitted the 'fix' that Tobias over on the EMTB Facebook page has developed. Very easy fix and I can see what the additional 3D printed part offers. Fingers crossed it offers enough of a fix (as well as the Zip ties) until the official Canyon and Bosch remedy is released.
S1mmo
97
74
Yorkshire
I have also installed the Tobias latch plate but I'm not using zip ties or any other method of securing the battery.
Hopefully it will last until the mysterious Canyon solution is revealed.
jxrx
100
37
Zürich
I’ve also gone the non zip tie route and hope it’s sufficient with Tobias’s fix.
RJUK
586
305
Out of interest, do you have any pics and what does the "fix" appear to achieve? Does it just better spread the weight of the battery across the latch or something?
Tubby G
❤️‍🔥 Hot Stuff ❤️‍🔥
Dec 15, 2020
2,702
5,427
North Yorkshire
Hi guys. I took delivery of my StriveOn this week and have been slowly preparing it ready for the trails.
I also fitted Tobias’ latch fix. The latch still seems fairly easy to be opened, i.e. the slightest touch on the nylon cord opens the latch completely. Is this normal ?
Niklas
44
51
Sweden
Try it without the fix…
S1mmo
97
74
Yorkshire
Mine seems to be wedged fairly tightly with the Tobias fix but it doesn't make the same click as before when closing the latch.
Have you checked the battery socket in the down tube at the opposite end?
Mine was quite loose so I removed all the bolts, loc-tited and reinstalled, it's been fine since.
Tubby G
❤️‍🔥 Hot Stuff ❤️‍🔥
Dec 15, 2020
2,702
5,427
North Yorkshire
The battery is solid, no movement, and when the latch is closed it’s solid too. It’s just when you pull the nylon cord the latch opens surprisingly easy, literally the slightest pull on the cord opens the latch fully.
When the skid plate is attached it all feels fine, so I’m probably concerned over nothing. A previous Bosch motored bike I had the battery locked into place with a solid firm click and it was actually quite difficult to then remove again. This one seems the opposite end of the scale, surprisingly easy to remove
jxrx
100
37
Zürich
Wow how would you even access that? You’d need a tool there what 60-80cm long?? Or am I missing something obvious like another access point?
el.guillyt
46
16
Spain
Don't worry, just remove the bracket where the battery latches, and your arm can fit inside de downtube, I've got fairly big arms/hands and no problem, you just need to undo the 2 bolts from the outside and it will come out of the downtoube, just remember to remove the cover for the cables channel, because the cable comes back down to the motor
RJUK
586
305
Could you remove the screws one sta time and loctite them, so save the connector detaching completely?
S1mmo
97
74
Yorkshire
There are two more bolts inside the connector that may need loctite and tightening.
The connector / socket is easy to remove and inspect.
The cable covers slide out out freely but be careful not to bend them as they're very thin.
When reinstalling the connector and replacing the cable covers just be careful not to trap or knick any of the cables.
RJUK
586
305
I already have noisy cables - made a thread about it on here with a video but didn't get any answers. Do yours also make a noise when you turn the handlebars? Mine move around in the downtube and make a noise. A bike.mechanic noticed it when I took my bike in to have a piece of PPF fitted.
S1mmo
97
74
Yorkshire
Mine don't make that noise.
Isn't that just the braided cable sheathing catching on the cable tray lid?
Have you tried sliding the lid back a bit to see if that makes a difference?
RJUK
586
305
It seems to be the cables moving side to side in the downtube as the bars are turned. And yes, I think it's that weird sheathing making the noise. Not really sure what to do about it.
jxrx
100
37
Zürich
If you go back to post #140 @eddie89 explains how to do it.
It's easy enough to do and worth trying.
Yikes I did go back and look at it and I'm concerned I'd screw something up or trash a cable so might not do this right now.
Can you see if the bolts are loose without removing everything first?
571K
