2019 Turbo Levo Owners Thread
Whizz
13
9
Belgium
In order to keep the same geometry you need also to increase the lenght of the fork to 160mm
@Levo Lution
I did it with magic mary 2,6 and the bike is incredible!
It feel more like an non e-bikes and is lighter
Flip chip in hi position and lyrik 160mm in front, bb is at 340mm instead of 342mm as delivered (29 / flip chip in low position )
Whizz
13
9
Belgium
Can you post picture of the bike, please, thank you.
Here it is:
Magic mary 2.6 are a little bit bigger than butcher 2.6 but it’s better (and butcher 2,8 a too big)
slowbrain
31
33
Norway
galaga187
810
606
Wroughton
If sticking with 29er wheels for UK winter riding is it worth switching tyres from the offset? If so which tyres are good please? I will want to run tubeless. Riding chalky, flinty paths, forests and occasional bike parks red/blue runs. Rider weight 90kg on speccy 2019 comp Carbon. Thanks in advance.
James_MTB
303
289
I'm currently running 29x2.5 Maxxis Shorty Front & 29x2.4 DHR 2 rear. (There's a new 2.6 due soon'ish)
When it gets really muddy; I love the Michelin Wild Mud Advanced Reinforced MTB Tyre 29x2.25 loads of grip.
In the 2.6 range, you've got Magic Mary, Specialized hilly billy and Bontrager SE5.
GunnyAmp
40
27
Gunnison, CO
Loving my Base model but need to add a dropper. Should I go with the Manic 34.9 or is there a better option. Also, anyone want to sell your stock dropper?
You can get the Bikeyoke's Revive Max if you want the 34.9 mm BikeYoke dropper posts
However get the shim and choose from plenty more droppers.
I've got myself OneUp Components OneUp Components dropper post and I'm very happy with 170 mm travel. Great price/performance ratio.
Thanks! That looks like a nice setup. Which remote should I add? Think it should be Shimano but I am a newb
hgray
10
14
SoCal USA
@Levo Lution
How is the handling compared to the 29er? I'm a shorter rider (5'3") and miss the ability to be more playful. I've been riding my 2019 Levo for a month now but I still struggle on tight switchbacks specially going downhill.
GunnyAmp
40
27
Gunnison, CO
I installed the rockshox stelth reverb with the 1x remote. The 170 mm dropper will fit in a XL frame even all the way down. Happy with it so far
You think it would fit in the LG frame?
Kiwi in Wales
Short cranks rule!🏴󠁧󠁢󠁷󠁬󠁳󠁿
1,241
1,589
Carmarthen, Wales
Anyone know how tight that nut needs to be? Mine came loose just from removing the wheel
Hi,
How tight it needs to be is actually displayed in your photo.
40 Nm.
You will need a torque wrench with the correct Nm range to carry out this task.
If you do not have a torque wrench..... 40Nm is fairly high so to get you by until you get yourself a torque wrench or borrow one from a mate you will need to tighten it up with quite a bit of force but try not to go too overboard and just keep an eye on it by checking every ride until you get hold of a torque wrench.
James_MTB
303
289
Looks cool! What is it? A peice of shaped rubber?
From Antony at bikescene
"Its just a rubber tube cut up with a plastic shim to secure it at the bottom. We’ve made a template so it’s easier to make in the future. The top section is just held in place with double sided automotive trim tape. This section acts as protection for when stones get caught up there too. "
571K
