Bafang M500 V2 vs Bosch Gen 4
Kyokushin
332
195
Sol
you need to copy and paste to empty file, name it "loginbypass.py" (extension must be .py, by default system may create you .txt but that will not work, so take a look on that), then run in cmd
Puschtrale
220
166
Dobbiaco
So i did copy the file in a empty file and saved it as loginbypass.py
Can you tell me with what comand i can run it within the command prompt?
Kyokushin
332
195
Sol
Create folder named „bafang” in „username” then place there a script and run it:
c:\username\bafang\loginbypass.py
Puschtrale
220
166
Dobbiaco
Thanks mate! Now i have it! I had to just double click on the file loginbypass.py to run the script. After it i can login the Besst Software with any account and passwort :)! Now i hope the Besst Tool will arrive today to be able to upgrade the firmware you mentioned to get more peak power out of the m 500. I am curious....
Did you experience also lot of less battery capacity due to the increased max power? And is there still the problem of less power when reaching under 30 % battery? Thanks for your help, i really appreciate it (y)(y)(y)(y)(y)
thaeber
888
769
Bruchsal, Germany
May be it sounds stupid..I created a file in the text editor, copied all the script into the file, and saved it as described. If I doubleclick on it, I'm asked which programm to use to run it. If I choose text editior, the script opens, but nothing is happening. Sorry, but I'm really lost...
thaeber
888
769
Bruchsal, Germany
..and really stupid. I need to install Python and the other software required first, correct? Unfortunately my Windows laptop is VERY old, and Python does not support the old hardware (processor). Looks like I have to talk to a buddy with more up to date hardware :)
thaeber
888
769
Bruchsal, Germany
Ok, 32 bit version of Python successfuly installed. Now I'm struggeling with this simplejson installation. I get the following result: Command "pip" is wrong or type error. What do I do wrong? Thanks!
Kyokushin
332
195
Sol
During installation of python you need to mark checkbox as in the manual, after that - restart PC and command should work
  • BafangVirtualServer.pdf
Pyr0
552
410
Wirral, UK
You may have to add pip directory to the system PATH variable.
[edit] or reinstall following the instructions linked by Kyokushin
thaeber
888
769
Bruchsal, Germany
so far, so bad :) Everything worked now, thanks for all Your help. Next problem: I edit the "hosts" file using the text editor. If I close the file, it's not possible to save it within the "etc" folder. I'm logged in as Admin. If I run the script with the Editor Window open, the script is not executed...
Any suggetions? Thanks in advance!
Puschtrale
220
166
Dobbiaco
Try to save it in another folder, then copy it to the etc folder and delete the old one
Kyokushin
332
195
Sol
Is it suitable for the M600 engine?
Or is there a separate branch of the firmware on the M600?
M600 have different firmware. I am attaching the latest for now (CRX10NC4818i132046.7-28-2230-20201121.bin) bafang official for M600.
M600 have around 1kW of peak power.
  • CRX10NC4818i132046.7-28-2230-20201121.bin.zip
Kyokushin
332
195
Sol
working as intended, and now run the besst (do not close the cmd with script).
next steps:
a. upload and pick file
b. after beeps - unplug the besst cable from bike. NOT usb from besst or laptop, but BESST connector to engine (single plug)
c. wait few seconds then connect and update will proceed automatically
d. click 'reset' after beep
571K
