Sorry if there is an existing thread. Searching "m560" only yields this oneseems like m600 ,but with magnezium housing 3.3 kg weight.There is one member in the forum who is expecting this motor for testing.
Is the m620 a moped motor? (he asks rhetoricallySounds like a moped motor more than an e-mtb motor.
Mate M510 must overperform brose.
I disagree, my M600 without throttle will keep up with the Brose's of my friends Specialized turbos fairly comfortably and I suspect that it maybe a tad more powerful. But I do have a caveat, I run mine on a 52 volt setup and can see well over 1000W's on a full power climb ( which I very rarely ever need to do ).I can say for SURE the m600 is weaker than the Brose with "current" firmware while in IN A CLIMB WITHOUT THROTTLE.
Sure it is, it's lighter and has more torque and power. It's kind of an improved M600 imo.Te Bafang M560 spec's sound like a light version of the M600 motor.
Interesting that you mention in low cadence that the M510 doesn't climb well, which must mean that in order to get the 95Nm out of it you have to keep your cadence on the higher side. Max cadence is 120rpm, so I guessing that you have to be 80rpm or higher to get the Nm out of it.Really looking forward to hear real world reviews on this motor! If it has the same tunability as the newest m510 but can give more torque in lower cadence that will be a big improvement! M510 was a huge improvement over m500, but still lacks in the climbing department imo.
Would you say that the M510 95Nm is not a true 95Nm?Really looking forward to hear real world reviews on this motor! If it has the same tunability as the newest m510 but can give more torque in lower cadence that will be a big improvement! M510 was a huge improvement over m500, but still lacks in the climbing department imo.
You said they will be using for upcoming frames? Just looking at the image I would say it's the same bolt pattern as on m510/m600. Overall it seems it's the reworked m600 that was modified the same way m500 turned into m510. They even used to call it m610... These are of course just assumptions, so if you have different info I am curious to learn.It's not quite the 'M620 killer'. But I suspect it'll soon replace the M600 on future emtb's who licence bafang motors.
Dengfu and Frey will be using this motor on upcoming frames. Unclear as to other brands.
But it is worth mentioning that this motor is considered a class 3 motor (not a 250w nominal motor).
Yes, or as we say it's 95 'Chinese' newton meters theoretically it can produce this torque, but definitely not in a steep climb situation.Would you say that the M510 95Nm is not a true 95Nm?
Here's the good news: It looks like the M560 is a drop-in replacement for the M600. Bolt pattern/wiring looks the same.It's not quite the 'M620 killer'. But I suspect it'll soon replace the M600 on future emtb's who licence bafang motors.
No full review but ill tell you my take... (notice I reordered by powerIt would be great if someone who had access to all of the Bafang motor line could do a review and compare of the the following motors:
M820
M600
M510
M560
M620 (The Beast of a motor)
I see 800w max on my M510 FC 2.0 without throttle. Never had problem with steep climbing on level 4/5 level assist. Can tune it via besst pro.You bike is highly modified! Us stockers are seeing different performance.
I do see 750 watts but only when I add throttle - never on pedal alone. My cadence is over 60rpm FWIW.
