2019 Specialized Turbo Levo. All the details confirmed S-Works PICS
Status
Not open for further replies.
paquo
463
284
usa
isnt the 2.1 motor the old lump that has been refreshed and not necessarily different bolt pattern ?
Lxmaso
29
33
Venice
Not good news about the weight. My retailer confirmed everything we already know but the Expert will be around 22 kg... he also said the margin is reduced so probably no more 22% discount as before.
Ps: bikes in store already but in the warehouse until the official launch.
He invited me to take a look already but I have no time until October.
neils
218
118
Alton Hampshire
I guessed that would be the case......they made everything else lighter to cater for the extra 700W battery weight
neils
218
118
Alton Hampshire
I'm think we're all going to know this Friday, so only 2 days! :)
All bikes in the range will have the new motor, but I think only the Carbon (Comp, Expert, S-Works) models will possibly get the bigger 700w battery. Don't hold me to that, lets see on Friday.......
StuR
449
731
Forest of Dean
Just got a VIP invite to Rutland cycles.
Apparently they are launching something a bit special next tues :unsure:
Tempted to bunk off and go
Anyone else going to a launch ?
Lxmaso
29
33
Venice
My Specy retailer confirmed today only Expert and Sworks have the 700w battery. IMHO if the 700w has different cells than the 504w, then the electronic to manage the different cells should be different: so IMHO (again) it will be not possible to switch from the 504 to the 700.
Doomanic
🛠️Wrecker🛠️
8,877
10,707
If the voltage is the same and it's just the capacity that changes then the 700Wh battery and 504Wh battery will be interchangeable assuming they are the same physical size.
ccrdave
1,428
1,125
uk
The 2019 hardtails have 400w and 500w batteries as opposed to the previous 460w and 504w
Thomas
248
255
Europe
If they changed the design of the frame and the battery is in the frame, removable from the bottom, than there is no compatibility.
eFat
342
270
Switzerland
Compatibility with the current one? Certainly not. But between the new 500 Wh and 700 Wh it makes sense.
wildsau2
167
123
Germany, Karlsruhe
So here are the true rumours that we know as fact (from the rumours thread). SO these are now the facts, no longer rumours. I have picked out all the stuff so we can keep it in one place.
Specialized are about to launch an all new 2019 Levo on the 18th September. Below are the full confirmed details.
The bike should feel significantly different to the 2018, with revised geometry, lighter weight and longer travel. The pricing has increased by approximately 12% across the range, so expect to be paying out a lot more dollars in return for what looks like the worlds most advanced EMTB.
Pictures have been leaking over the past few days and we are now in a position where we have an excellent idea of the bike, down to the exact specification of the Expert and S-Works model.
A few standouts that are worth calling out are the move to 29" wheels, an all new, asymmetric frame based on the 2019 Stumpjumper, an all new display on the top tube showing battery and motor modes (photo has been removed), all new way of integrating the battery into the downtime (sliding it inside the tube). The battery will be 700 Wh on the Expert and S-Works models, and 500 Wh on the other models.
Only the S-Works and Expert level are getting the increased battery. All in the range will get the new 2.1 motor.
The 700 Wh battery WILL fit into all the models. So you can buy a Comp and later a 700 Wh battery.
The new 2.1 motors are the Brose Drive S Mag motors. These offer a 15% smaller size and Specialized are mentioning an 11% weight saving.
[Edited to update the battery, and 2.1 motor confirmed on all models.]
2019 Expert with 150mm RockShox Pike. New frame, with battery fully integrated into the tube, inserted from the bottom of the frame.
From Specialized:
"The Customized 2.1 Rx custom trail-tuned engine is 11% lighter than its predecessor. This puts it at the peak in terms of EMTB motor technology. It has many other features that no other electric bike can boast, such as instant operation, fantastic heat management, double free pinion design that disengages the gearbox when you reach maximum speed and a silent, smooth and even output, even at maximum power"
"The new turbo specialized battery m2-series has 700wh capacity providing 40% more capacity and range, and even more power to travel more trails. And of course, it fits perfectly into the frame and is easily removed."
"The design includes our 29 trail Geometry that features a low bottom bracket, long top tube and short stem. The kinematics of the frame has also been perfected, with the necessary stiffness. The cable guidance is completely internal, including that of the Post Command Post IR, the battery is completely integrated into the down tube, while the minimalist motor is mounted in a more secure way and is lighter than ever."
In Summary
  • All new frame based on the new 2019 Stumpjumper. Asymmetrical design with revised geometry
  • 150mm front and rear (up from 135mm rear)
  • All new 700Wh battery that fully integrates into the downtube (slides right inside the tube from the bottom) on Expert and S-Works model
  • Up to 40% more range than before thanks to the new 700Wh battery and more efficient motor
  • New 2.1 Rx motor, featuring the Brose Mag S. 15% smaller, 11% lighter and custom tune
  • 29" Wheels (up from the 27.5 on earlier models)
  • 2.6" Butcher Tyres (smaller than earlier 3", then 2.8" on earlier models)
  • All new LED panel on top tube, showing battery status and current motor mode
  • 160mm Dropper
2019 Levo Comp Specs. Expected Price: TBC
BeBop.
thx BeBop
waiting for the Comp ST.
saving another 700g.
Doomanic
🛠️Wrecker🛠️
8,877
10,707
I meant compatibility between the 2019 models.
This is what I meant. I wasn't aware the new battery was 500Wh, not 504Wh.
I have a feeling that a fair few shops have stock locked and loaded ready to roll out
Adasb
64
71
New Zealand
That's the case in NZ. base spec Levo's are in-country, but higher end (expert / SW) are Oct / Nov delivery.
I've got my name on a pair of SW for me and my wife...!
bekolu
54
18
If I look at the Comp model, the upgrades are new 29er frame, new motor, new battery type and potentially upgrade-ready to 700w plus the Revelation having the charger unit and the debon air already included. Price increase is 10% - not to bad, isn´t it?
My 2018 Comp Carbon has 22kg with tubeless Butcher 27.5/2.8. The new Comp will save some weight on the frame and the motor. But what about the new battery compared to the current 504w? The 700w will probably heavier but will the 500w be about the same weight as the current one? If this is the case will the Comp be at the same weight as the expert and/or the S Works?
Thomas
248
255
Europe
Any thoughts way pay 1200 EUR more for the Alu LEVO FSR COMP instead of entry LEVO FSR? :unsure:
I guess redesign of the frame will only accommodate new motor and the battery, so this will be the same.
On LEVO FSR, we will probably get cheaper components, like shocks, groupset, NO Command Post and maybe cheaper wheelset.
If someone is buying aluminium version of new Levo FSR, wouldn't it be cheaper and better, just to upgrade all those components to your liking and sell the ones that came with the bike?
Status
571K
