• Warning!!
    UK Pedelec Law
    Worldwide Laws
Derestricting bosch smart system
JP-NZ
1,380
1,080
Christchurch - New Zealand
Currently Amflow will be totally derestricted if you set it to NZ.
I believe its not "unrestricted" doesn't it just change it to the US/NZ 20mph max?
nativeracer
34
41
California
Well, I'm hopeful at least in the States that Bosch will be forced to increase the cutoff of their motor systems. Otherwise, most people will not purchase a new bike when Spesh is about to give their customers the choice to raise the limiter on the new Levo. This choice should have always been left up to the consumer and not the manufacturers. Besides, I'm not sure how often you guys ride on private land, but I certainly do a lot of rides on private property.
ScubaDrunk
13
It looks very good. Sadly I have rim magnet no brake magnet 🤔😏.
You can have that converted by your local bike dealer very easily. They remove the RIM magnet and replace with a cable and sensor from the motor to a new hub magnet on the rear wheel. they then reprogramme the software to use the external sensor instead of the builtin motor sensor.
Suke
Czechia
Yes that is true. I will contact few around me. I found them on bosch site.
I read a few problems with this planetary gears. Bikes going to limp mode. Sooner or later..
Maybe I Will just wait for a good chip. I hope they will be. I heard volspeed working on it. It will be available in summer.
Trickz
300
285
Burton upon Trent
Thanks for info👍tbh I’m getting ok with the cutoff now and will wait until something reliable comes out,idk how good speedbox are but they are apparently working on kit.
578K
