Levo Gen 4 Levo Gen 4 Rumours Born-Again
MarkE192
27
34
Unlike other brands that recently released their bike it does not seem like Specialized was that focused on weight. I can tell you I have heard that the new motor performance is outstanding(like nothing currently on the market) and the new frame design is one of the best handling all mountain bikes produced, but until the 8th it is still all speculation. I am sure there will be lovers and haters as there is no perfect bike fits every ones needs. I do know I am excited for my pro to get here next week and take it through its paces.
WatermanJim
52
48
Ocean City, NJ
Just talked to my LBS and they will have them on display Tuesday. He was not allowed to give any more info.
Does anyone know the color choices for the expert and if the bikes have auto/freeshift?
Power1tobe
47
34
VA
I know that it has and Apple locate feature and is more SW defined to adjust the motor response, so and improved app. This should make for a few good stories of ppl hunting down thieves. Personally I think it should have security features so you can disable the bike if you walk away. I mean its the price of a beater car.
21,413
Historically it wasn't a problem as Levo's could self disable with the first pedal strike or some other random touch.
Jun 12, 2020
93
75
lake Tahoe
Hadn't seen anything on the alloys, the Specialized site I saw only had the whole carbon line. I am certain it will all be out this Fri.
Is there any info regarding the alloy version. I just saw a screenshot of a US dealer with pre order pricing and it included two alloy models. Alloy would be my preference but I am unsure how much longer I can put off buying, anything later than May is too long a wait for me.
Can you share the pre-order price list please ?
profgruen
65
19
Austria
Which colours does the Pro have?
Is there also a black one?
David666
71
54
France
Old cells on that one, new cell 800 Wh batteries are sub 4 kg.
Probably but it wasn’t really the purpose of my table. 800wh battery weight is just an approximate guess.
Then, weight without battery would be even under evaluated in my table. It’s even worse.
I read in the past posts someone saying that with small battery option, it was possible to get a Gen4 not so far from a SL but I do not foresee it realistic…
BikeBert
114
689
Croatia
Does anyone know when the Ohlins limited models are available ??
I thought this one was hot ..
I built my own 'Öhlins Limited' long-travel version (170/165 mm) using TTX22M.2 + Cascade and Fox 38 with a Smashpot coil spring and an Avalanche open-bath cartridge.
Nothing beats the buttery smoothness of a coil spring paired with a high-oil-volume damper. The stock Levo was cute, but after the coil conversion, it turned into an absolute weapon.
576K
