What is the pro Modell? This is Not the SWORKS?
Are you actually a badly coded chat bot? Your posts here add zero value.
I was wonderingAre you actually a badly coded chat bot? Your posts here add zero value.
People seem to have different experiences with Specialized dealers. I have so good dealer that it's main reason to buy Specialized. I had only two warranty case, motor and freehub. Both we handled immediately without questions. Motor wasn't even broken, but there was clear evidence that it will be soon (sprag clutch...?) and freehub I maybe broke myself when I dropped it and they changed it anyway, even that I told what happened![]()
Not to be confused with the Comp AlloyYou forgot Alloy Comp ...
Not really or unusual it's just Specialized policy.Strange isn't it, i had a cracked chainstay and sent it into a Concept store here in the UK. Came back with a new battery and motor without even asking for it. Replaced under warranty, about 4 months out of warranty.
So not like a S.L.If you ride Santa Cruz or Norcal, you have likely already seen it. Most of the rumors are true. Based on specs, it kills all other ebikes aside from it being 150/160. Just don't anticipate a good looking bike because the aesthetics are horrible. It looks nearly identical to a gen 3, but the pregnantness moved more to the downtube....
So, assuming you saw a Gen 4, courious about the model you saw (i.e. S-works or Pro), color rear shock. Did you observe that the sidearm has been deleted along with the hump?If you ride Santa Cruz or Norcal, you have likely already seen it. Most of the rumors are true. Based on specs, it kills all other ebikes aside from it being 150/160. Just don't anticipate a good looking bike because the aesthetics are horrible. It looks nearly identical to a gen 3, but the pregnantness moved more to the downtube....
That just reads like a ChatGPT summary of what’s been posted in this thread.Here is a link to a Canadian site which provides some interesting details. It mentions the 120 NM feature built in to the SWorks only model ( as has been mentioned previously in this forum). If true, it may imply that this is achieved through software or perhaps a separate boost controller/mode applied to the same base motor?
2026 Specialized Turbo Levo
2026 Specialized Turbo Levo, featuring three battery options, a lightweight Stumpjumper-inspired frame, Genie shock, adjustable geometry, and a powerful S-Works motor with 120Nm torque. Experience a more efficient, versatile, and high-performance eMTB.www.mountainbikescanada.com
Exactly (and not all accurate).That just reads like a ChatGPT summary of what’s been posted in this thread.
This was already mentioned here before, really interested to see how are they going to do it just for the sworks, because if it’s just a software limitation then all we need to do is ask nicely to your local spesh dealer and we will have it on all modelsThey really are doing higher torque for sworks....
Could be linked to the serial no and …. every other Modell is out…This was already mentioned here before, really interested to see how are they going to do it just for the sworks, because if it’s just a software limitation then all we need to do is ask nicely to your local spesh dealer and we will have it on all models![]()
Just as they sniff the gen 3 bricked motors that come from derestricted bikes with range extenders? I’ve seen 6 go into warranty and come back newI'm sure that door is blocked since it sounds to easy and loss of profit and if Specialized sniff it dealer is out of business.
Indeed you may be correct. It will have to be different than what others such as SRAM will be able to offer. Specialized will want their own thing. Who can blame them.Sounds great! But Brose will be on board. Not named Peak3 but maybe Specialized 3.0???
Again: a small battery at a premium price is a ripoff. For the price you pay, the Vala should come with the range extender. Santa Cruz marketing convinced a bunch of fat wallets to pay more for less battery and range. I am hoping the industry will follow Ibis with the Oso with a full power Bosch and a 800wh battery for 6k…. That a carbon frame with axis and Fox suspension…. $6,000!If you ride Santa Cruz or Norcal, you have likely already seen it. Most of the rumors are true. Based on specs, it kills all other ebikes aside from it being 150/160. Just don't anticipate a good looking bike because the aesthetics are horrible. It looks nearly identical to a gen 3, but the pregnantness moved more to the downtube....
I'm not sure Santa Cruz offered the Vala with a 600wh battery to save money. Why would they? Would they be saving $50 USD at their cost? It was more about weight, for sure. While I do agree about the extender would have been nice to just "include", that's unnecessary. While I did purchase an extender on my Rise, I rarely use it. And think about it. The current Levo offers a 700wh battery which I find more than adequate. With 32 mile rides under my belt with the 700wh battery, can we conclude the new Gen 5 Bosch with better power management and 600wh with the extender for an extra 250wh is opitmal? 850wh? Who uses that much on a regular basis? As for Ibis, they didn't make the OSO with the 800wh to make a statement, rather they are trying to get rid of what must be a huge backstock that if not moved soon, will end up at Jenson USA at an even lower price. Yes, it would be nice, but Specialized has no intention of doing anything close to this. Would be nice, but wait til you see the S-Works bike at $14k... ugh, this ebike thing is getting wild.Again: a small battery at a premium price is a ripoff. For the price you pay, the Vala should come with the range extender. Santa Cruz marketing convinced a bunch of fat wallets to pay more for less battery and range. I am hoping the industry will follow Ibis with the Oso with a full power Bosch and a 800wh battery for 6k…. That a carbon frame with axis and Fox suspension…. $6,000!
They are out there for sure. Lurking in the background of friends Strava pics.If you ride Santa Cruz or Norcal, you have likely already seen it. Most of the rumors are true. Based on specs, it kills all other ebikes aside from it being 150/160. Just don't anticipate a good looking bike because the aesthetics are horrible. It looks nearly identical to a gen 3, but the pregnantness moved more to the downtube....
Small battery is to make bike looking better and save weight, not money. Oso has old Gen4 motor and 750 battery. Cannot compare. Also they have weird sizing….and side loading battery, harder to sell. Good package for that price thou.Again: a small battery at a premium price is a ripoff. For the price you pay, the Vala should come with the range extender. Santa Cruz marketing convinced a bunch of fat wallets to pay more for less battery and range. I am hoping the industry will follow Ibis with the Oso with a full power Bosch and a 800wh battery for 6k…. That a carbon frame with axis and Fox suspension…. $6,000!
