Bafang M820 Firmware thread
patdam
945
608
france
Which is the best firmware for emtb on 48v battery?
Personally i'm use this 4812.
But it seem i'm "particular" user (1.93, 100Kg, high mountain use).
i have power cuts if i use 100% power in hard uphill (normal following bafang return) and occur with all software tested. i have setted S+ at 90% and i never use BOOST (setted at 100%)
I consume +- 1/2 less than M510, currently now with 9.6Ah battery, i never consume more than 60% (1600 D+ at max)
  • CRX30PC4812E102012.1_240412.bin
like-bike
52
13
Italia
Hi everyone, I have a problem with the firmware of my m820 48v. I should have the 25 km/h limit by law. I sent an email to Bafang but after a few emails nothing, he told me that it can be done with the phone via bluetooth.
Freda
177
153
Vaasa
So if I understand correctly your limit is too high. You can only limit the assist speed by a percentage from max with GO+ app. After you need to test where it actually stops assisting and adjust if necessary.
Only with BESST tool can you set an exact speed limit.
like-bike
52
13
Italia
ok thanks a lot, bafang told me that via BT it was possible to update the firmware, made by them for me, to have the right limit. I don't know anything else. Too bad that from a smartphone it can't be done.
Freda
177
153
Vaasa
OK, now I understand. Yes you can update your firmware with the GO+ app. With the serial number from your motor it will automatically find update for you. You can not choose any other, only update or not update. That will probably solve your problem.
like-bike
52
13
Italia
well I don't know I tried from the app but I can't do anything. I think I'll buy the BESST, since Bafang doesn't answer me anymore
like-bike
52
13
Italia
hi, my engine does not communicate with my DIY battery and therefore my residual charge percentage is wrong. I don't know how to do it with the BEEST. does anyone know how to do it?
ficorama
408
323
Croatia
Greetings. Try another firmware. The same thing happened to me with one firmware. I don't know which one now, but I'll try to find it.
Coolspot
Quebec, Canada
Hi guys!
I just received my M820 to use on my LCE930 with Bafang 43V battery
Current firmware is CRX30PC4310E102001.6 (see attached picture)
Reading the 4 pages here it seams I have a 10A firmware for Road... Is it really the case?
Before updating to CRX30PC4313E102001 3_eMTB_230317 found on this thread, I want to know if the "2001.6" means it's a newer firmware than "2001.3".
Is there a way to backup my current firmware? I don't want to push an older version and not be able to put the one originally there.
Another question: when trying to cloud update with BESST Pro I get an error message saying my serial number should start with CR..
I do have a BESST Tool.
thanks!
NWCO Emtb
9
Steamboat Springs Colorado
Hi guys!
thanks!
I'm in the same boat. Waiting on my my K1 flash to arrive. Then try and put put my less then qualified tech skills to work?
like-bike
52
13
Italia
hello everyone, i have a problem with the engine. after the first ride, i customized the engine a bit. but now it seems to me that it doesn't give me the power that it should give especially uphill. in the first ride on the display in boost it was indicated up to about 500/560 W. now it is 120/130 W. why? and still the battery percentage is not exactly right. thanks
Freda
177
153
Vaasa
As has been discussed here before, the percentage scale is wrong from bafang. 20 percent on display, is 50 percent on my bms. That is why it is even more enoying that battery saver starts already at 20 percent.
You can take out more of the battery by using 43V firmware with 48V battery or 36V firmware with 43V battery. It takes the battery down to 20 percent on bms when battery saver starts. This also gives you somewhat more power, but it makes the percentage scale even more messed up. It shows 100% until around 70 percent battery, then drops more quickly.
like-bike
52
13
Italia
ok but sorry Bafang can't you fix this and/or give the possibility to remove it?
Apr 1, 2023
19
16
Poland
not possible tachnically i think 410wh battery 12s2p so only 2cells working together when you load 500w at only two dischcharged cells voltage drops dramaticly ,bms cut off voltage and ride finished :)
Radolf
45
49
Poland
Hi. Do you have any info whether Bafang has released any new software versions for the M820? I am particularly interested in the FW43V. Or is there any way to contact Bafang to fix the problem (in my opinion) of the motor working too long after pedaling?
Waynemarlow
1,156
927
Bucks
Back peddling by even a few degrees will instantly kill all the power, easily learnt skill and it will allow all of us who enjoy the run on to continue to use that few milliseconds of run on to get us up difficult steps and through deep ruts without fully peddling.
Radolf
45
49
Poland
I'm not talking about ms but about 2 seconds or maybe even almost 3... Of course, a short stall can help on a technical climb, but sometimes there are situations in which too long a stall is dangerous - I know that it's not just my observation about too long a stall (which doesn't always happen).
Waynemarlow
1,156
927
Bucks
So just back peddle ever so slightly and you won't have the problem. Mine is the 48V version and it has supposidly the longest run on, but its no where 1 second let alone 2 seconds.
Radolf
45
49
Poland
I've ridden many versions of FW for 36, 43 and 48V batteries (of course, I'm still talking about the M820 engine) and I know the engine's behavior depending on the FW version... I agree with you, for FW48V the engine stall is OK but as I've already pointed out for FW43V it sucks! It's best on FV36V. I've already written about my observations regarding work on individual FW versions.
But back to the point, anyone know who needs to be slept with to get the information about this problem with FW43V to Bafang?
Ger@nio63
94
56
Italy
Hi I have a Cef-50
arrived in mid-December with the engine with the characteristics you see in the photo. In the engine you can only find the sticker you can see, no stamped number as in the previous engines. Someone recently received an engine with the same characteristics ❓
I contacted Jean from SZZT to get some information on the speed and firmware since it's an e-road. She tells me that I can't change the firmware because my engine is a 48V and if I do it with Bafang Go+ it stops. I don't see any sticker or punch in the engine that says 48v, do you have any suggestions for me🤔
Radolf
45
49
Poland
It can be assumed that if the manufacturer provides FW for 36V, 43V and 48V batteries and does not say that there are 3 versions of the engine, it means that every M820 will support the above software. Therefore, you must have BESST TOOL + FW that you want to upload and that's it (GO+ you will not change the engine FW).
578K
