Trek rail rear shock upgrade ideas please
Zed.
48
100
Deepest Bandit country (Wales)
I agree with comments already made that the piggyback on that Mara looks way too long to fit an aluminum Rail.
Manitou make 2 lengths of piggyback thinggy with the longer on 'Rail sized dampers (although can be bought aftermarket and aparently easily swapped :unsure:
Manitou are having a sale (on their website) so lots of heavily discounted prices.....
^^ Usefull IF you live in USA / Canada but not so good in the UK as wont ship :rolleyes:
Rich.
stefino
rimini
After several short landings, unexpectedly, I found no sign of impact between the shock absorber and the frame. The bike is a 2022 rail5 size L and the shock absorber is a
Rock Shox Super Deluxe Ultimate RC2T Debonair (no Trunion) 2023 wheelbase 230 mm stroke 57.5 mm
irie
2,060
2,014
Chichester, W.Sussex, UK
View attachment 138096 View attachment 138099
If it was me I would let all the air out of the shock to be sure that the reservoir does not hit the downtube. Easily checked.
SandroRiz
35
13
Italy
Fitted a Cane Creek DB Tigon - Standard 230 x 57.5 to my Trek Rail 9.8 , smart system 750, size M, MY 2022, fits great. Interesting shock as it has a coil and also an air shock feature to add progression and bottom out protection.
I see, if I'm not wrong, a fidlock bottle cage.. does the standard one not fit?
With this, can you have 500ml bottle or less ?
Thank you
irie
2,060
2,014
Thank you
(2022 Trek Rail Alloy Large). With an Ohlins TTX22m.2 coil shock the largest bottle I can carry is 600ml and had to modify a bottle carrier to as high in the frame as possible to prevent the top of the shock hitting the bottom of the bottle.
SandroRiz
35
13
Italy
Thanks Irie... I asked Josepi because I have a M size too...
until now, for my knowledges, on the M only the EXT e-storia (see my post here) is compliant wuth the standard cage (500ml)
JariL
9
21
Finland
Same with Rail 7 gen3 XL and EXT e-Storia. But Rail with e-Storia is super good!
mteebee
Finn
My Deluxe select+ need service but it`s 4 years old and I think it`s better upgrade. Ideas? Trek rail 7 2020 aluminium size L fork rs yari (motioncontroll need replacement too). Air shock is ok I just ride trails with rock gardens no DH sessions. Price should be less than 400€, dvo topaz 2(if it fit?), fox dpx2 performance or rs deluxe ultimate...
Zed.
48
100
I've been running a Manitou Mara (230x65) for a few months on my Medium rail5 and found it exellent, we have a few other dampers in stock...
Manitou Mara, Fox float x2 evol taken from My Mrs's S-works kenevo sl and an Ohlins Ttx air - all in 230x65.
curiosity (& mrs demanding my opinion of the Fox damper :rolleyes: ) and trial-fit on the rail..
it fits in it's extended state (actually clears the seatpost.
but, clashes with the frame on compression (not full stroke of 65mm BUT the standard rail stroke is 57mm I believe:unsure:) so didn't test-ride:(
so fitted the Ohlins and gave it a shakedown Saturday & Sunday @ Bpw😎
I'm ~110kg so no lightwieght!
same ~20%sag as riding red tech trails with some attempts at smaller jumps (white men can't jump?)
Manitou Mara 170psi
Ohlins 245psi
the Mara follows Manitou's low operating working pressure (I have Manitou Mezzer forks and run between 60psi & 70psi in the main & negative spring chambers depending on how I'm feeling!
whereas the standard-fit Rockshox forks needed a lot more - Rockshox rear damper needed over 350psi in its airspring to not constantly bottom-outo_O)
both similar compression & rebound settings (basically open)
so, what do I think?
both the Manitou & Ohlins are good, similar support from their airsprings but I seemed to use slightly more travel on the Ohlins🤨 damping wise I found them as good as each other😎
I'll probably keep the Ohlins on the bike a little longer for a better appraisal but want the mara back as it just felt that little bit more comfortable😯
Rich.
NicksRR
Spin the shaft 180 degrees so the knob is at the back.
I know it's an old post but sooo glad i read this. I've just been shitting it that it won't fit, so thought i'd scroll back. Just got to swap the spacers over. Cheers for the obvious and life saving answer will post a pic once I get it on :)
526K
