New M820 frame from Seraph/TanTan, the E67.
clix
186
209
EU
Regarding the battery going to sleep, I believe it was written before in some other thread before. What turned out to be the case is, that person received the wrong wire harness. Essentially, battery BMS was not connected to the motor, so the only way to wake it up was to plug it in.
To check, the round green connector from the battery, do you have this one connected to the wire harness or is it hanging loose?
I also have original bafang 410wh battery from bafang, and I don't have this issue. I can turn on a bike that has been turned off for a week no problem.
Lvtride
21
15
Vancouver
Would you happen to have a picture of the wire harness?
Verdo07
26
9
Italia
I think clix was talking about this discussion....at least these are the correct cables....read the messages before and after too... ;)
Lvtride
21
15
Vancouver
Great. Thanks.
Verdo07
26
9
Italia
I'm 175cm.
sorry if I bring up the subject of the seat post again... with the 210 fully inserted, as I think it is in your case, what saddle height does it take you to? calculating for a moment he seems very tall x 175 cm... I'm 182 with 86 inseam and I pedal at 76/77cm but with your configuration I seem to be taller? where am I wrong? what is your inseam?
Lvtride
21
15
Vancouver
I haven't measured the height of the saddle but my inseam is about 82. The seat post is inserted as far as it'll go.
LAnton
560
468
Russia
Is everything okay with the new frame? There have been no new messages for a long time. Will the company fix the error in the frame?
temon10
677
570
Malang, Indonesia
Finally I can finish my E67 build. Final weight with 540Wh DIY battery is 20kg. Little higher than expectation but with tight budget it's OK. Maybe I have to change that heavy Magic Mary tire to Maxxis Dissector to get less 600gr weight.
Today I test ride about 26km and 580m elevation gain, battery left 88%. Later will test the range with my 360Wh and 180Wh battery extender.
SO far the bike looks so good, slim and easy to handle downhill or uphill.
Verdo07
26
9
Italia
beautiful bike!!!
is the rear wheel 27.5 or 29?
Fox 36 150 o 160 mm?
if they made size L, I would have already bought it... I'm 182 and size M I think is a little small for me...
Congrats again on the bike
temon10
677
570
Malang, Indonesia
beautiful bike!!!
Rear 27.5
Fork Fox 36 160mm
M size feel like S, maybe u can ask them XL size
Verdo07
26
9
Italia
Rear 27.5
Fork Fox 36 160mm
thanks for the reply @temon10
but do you think a 29 wheel with a 2.4 tire will fit? on the manufacturer's website it says "29x2.6" but from the photos it seems that it is very narrow already with 27.5...
Verdo07
26
9
Italia
there is size M only. And no more sizes' plan in the near future.
did they really answer you that way?
I asked at the end of last year and they hadn't been so categorical... well!!! anyway I don't understand this policy...if they made at least the L size they would cover 90% of the public...there will be 10 of us in this forum alone who want the L size of this frame...bah!!!
if they had at least only made the L they would have covered many more people given that the frame is also small...
Adam Anderson
22
9
Canada
try the rest 4 choices
Log into Facebook
Freda
175
153
Vaasa
View attachment 140811 View attachment 140812
How do you connect the extenders? How do you balance the main battery to the extender?
571K
