Merida eOne-Sixty angleset
CTM
17
NZ
Hey I'm thinking of changing the headset/cockpit setup of my E160 700. Running the cables differently and seeing if an angleset will work . Has anyone tried this ? Can't find headset specs.
Teriatric
99
82
North East England
I knocked this up on the lathe. It's 15mm deep and lifts the BB about 6mm. Desperate to get the pedals higher but can't find short cranks for the EP8. I also shifted the control wire from the daft headset slot to the downtube by drilling a second hole in the cover plate.
CTM
17
NZ
That's neat.
I considered making the fork 170mm but the front end is already fairly high.
Have you removed the steering stop.
Basy
90
81
No reason it won't. There's always a way but I'm not sure I understand why you think there might be a problem runnning an angle set?
579K
