robikinkela
It would be easy to make irony about what happened to me in the afternoon, but this is not the case, I think it is something to be taken seriously. After an afternoon lap I put the Levo 2019 on the easel to do some small maintenance and I was intrigued in front of a sheet of leaves and some pine needles that came out of the left plastic casing. I do not want to make it long but what I found inside the engine compartment, after having removed the pedal and the carter, left me stunned; no need to comment on the photos that, in my opinion, are quite explicit. The offending material enters from the hole at the back of the engine, in the lower area where the wagon is hinged (see photo). Initially I couldn't believe that at that point there was a hole which communicate with the engine compartment but I had to change my mind. The fact is that this situation can be, in my opinion, potentially dangerous: the electric motor heats up and what you can see in the photos is flammable material. Apart from the maintenance, with a cleaning that, at this point, should be done regularly , I cannot understand that the designer could have been able to conceive such a shit! There must be an explanation. Or not?
