Could you perform a return to appreciate difference with M500. Distance / height difference / consumption / range (with your weight).im satisfied with the power of the m600 although i cant say for the longevity since mine is new
will do soonCould you perform a return to appreciate difference with M500. Distance / height difference / consumption / range (with your weight).
Exemple M500. I estimate aproximatively ability: 50% consumption for 20km and 1500m climb at 10 km/h, in middle mode, for an rider of 100 kg
Few days back i received response on fb from Innotrace that they think the X2 M500/M600 controller would be released around September earliestWe were hoping to have it already. If you are in EU, Innotrace will have it in a month / 60 days. Ditto for the US.
maybe you have loose contacts on the wires. just check againDoes anybody know an contact for bafang warranties ? i have tried: melody from dengfu, bafang "after sale support ", service@bafang-e.com, nobody answer ? Does somebody have really tested bafang warranty one day (apart those who have youtube channel ) ?
i have a problem with the controler (i suppose) sometime i cannot switch off the display or mosttly most serious, i can't switch on, i have thinked it is the remote switch, but i have tested with another display/remote and it's the same problem.
its a random failure, never when the motor is cold. i have unplug/plug all connections when it is occured and that do not solved the problem. I was able to switch on after 1/2 hours of ride whithout motor, i have actuated the switch and it worked well whitout any action on wires.maybe you have loose contacts on the wires. just check again
hopefully it will be fixedits a random failure, never when the motor is cold. i have unplug/plug all connections when it is occured and that do not solved the problem. I was able to switch on after 1/2 hours of ride whithout motor, i have actuated the switch and it worked well whitout any action on wires.
I think it is mostly problem of controler (hardware or software ?) than wires. I have cancelled the temporisation to economise power, in this way, the motor never stops by itself and I no longer have the problem of not being able to turn it on again when I use it.
Great news butInteresting information provided by an contributor on endles sphere. A link to a Czechoslovakia company who store spare parts for M500
Výsledky vyhledávání m500 - Elektrokola Zlín (elektrokolazlin.cz)
As bafang / dengfu do not insure warranty and support to maintain the motor, this could be an solution (if they agree to supply to other country)
Great news but
I suggest studying history
"Czechoslovakia"?!?
Here is a similar websites from the Czech Republic with the same price
Vyhledávání - Kola Cirkl.cz (kola-cirkl.cz)
MOTORY - Yesshop.cz
Elektrokola Praha 10 - servis a prodej (bafang) (electro-bikes.cz)
There are many more if you search well
Yes, not necesary a failure. It can occur if you use throttle at low speedgot an error 21 today. Speed Sensor?
not using throttle bt it seems my rear tire is somewhat loose that i think the sensor magnetYes, not necesary a failure. It can occur if you use throttle at low speed
between 5 and 25 mmHow far should the magnet be from the sensor?
Thanksbetween 5 and 25 mm
Vid out this weekend ?Hey Rob, any update on how the revised motor is turning out ?
better by a bit, still not near what I’d expect from a quoted 95Nm motor to be honest though...
Hi. I think what you experienced before is what I'm experiencing now. We're you able to troubleshoot it?So, after a year and 1800 km with the m600 i got a code 25. something to do with the torque sensor.I can ride the bike, but
If i ride 20km/h the display skips to 50km/h back and forth, so the pas acts unpredictable..I took out the torque sensor, examine
it, but cannot find some defect.
Maybe it has to be recalibrated. I have the besst tool and try this if i get an account with Bafang.
In the mean time I placed a new motor so i can at least enjoy my riding.
