Levo Gen 2 Turbo Levo 2022
Status
Not open for further replies.
rydeezie
612
866
san francisco, california
Well vid switched to private so I’ll just post a screenshot of the bike
I would like to see the Kenevo Prime vid....
CjP
PRIME TIME
1,671
2,394
Everywhere
To me it is Levo 2.5 rather than 3.0. Nothing really exciting. Tcu might be nice but if you use garmin you already have that.
Garmins are for gravel bikes. This is a serious weapon!
I can’t even wear my fitbit on my Levoduro SL is so badass!
1WD
Adelaide
Ok, new here.
Was just about to pull the trigger on a 2021Turbo Levo Comp, then the guy in the shop mentioned the new rage being announced this week… and well, here I am!
Looking forward to a breakdown of the differences between these two model years. ??
21,127
4 hours to go ....
You can guess quite a lot ..
New one will be nicer, faster, betterer ! :) OK, so I'm making words up too now.
As @salko says, it will probably have a new "M3 -700???wh" battery. Battery tech hasn't really moved on enough to give more and the images appear to show a different charge port, though probably still the same charger. Or it might be the old battery, just an updated version.
  • Like
Reactions: 1WD
1WD
Adelaide
4 hours to go ....
It’s bedtime here now in AU so I guess I’ll wake up to good news and reviews! Enjoy everybody!! ?
Jeso
Monaco
some tech info on french facebook levo fanpage ( scan of spe doc ) :
mullet 27,5/29 ( fox 38-160mm)
M3-700 battery,
motor 2.2 ( 90 nm - 565W )
sizing S1 to S6
very cool adjusting head angle from 63 to 66.5 and BB +/-7mm , that may confirm also 29 rear compatibility
rydeezie
612
866
I think I’ll hold off on buying the new Levo at MSRP
I’ll wait a couple months and wait to buy second hand at a lower price
other than being a carbon frame, I don’t think it’s much of an upgrade over my Kenevo Expert I bought from a rep for $5,500 (had 250 miles, 4yr warranty) . I like more susp travel so Kenevo Prime might make for sense for me to buy at msrp
Mullet 187R/203F or 180F
JetSedgwick
384
1,006
Lake Tahoe California
totally agreed
MrSimmo
1,096
1,048
The Trail.
  • Levo’s fully integrated Turbo Full Power 2.2 motor, 700Wh battery, and advanced MasterMind Turbo Control Unit deliver category-leading 90 Nm of torque and 565 watts of power for up to five hours of ride time, empowering you to ride farther and faster than ever before.
  • The MasterMind Turbo Control Unit is your information hub with customizable display fields, including the exact percentage of battery level, and it features our all-new MicroTune function to adjust power delivery in 10% increments, so you get exactly the support you need to experience precisely the ride you want.
  • A dedicated mixed-wheel size design with a 27.5” wheel in the back and 29” up front delivers a nimble ride that carves circles around other full-power e-MTBs. A generous cockpit centers you on the bike, optimizing traction and corner control. The low bottom bracket, slack headtube angle and reduced fork offset keep things stable in the rough.
  • Levo offers six distinct geometry settings, allowing you to easily dial-in its performance for any riding style andany terrain. Head tube angle can be adjusted between 63- and 65.5-degrees. Bottom bracket height can be fine-tuned up or down by 7mm.
  • Levo’s 150mm of rear travel is supple on small bumps, devours square-edged hits without a twitch, eats massive G-outs for breakfast, yet still offers amazing pedal response and delivers your power to the ground with total efficiency.
  • The Levo’s S-Sizing is based on what matters—rider size and style, not inseam. Six sizes, all with similar headtube lengths and standover, allow you to choose the size that best suits your individual style. Smaller S-Size numbers are going to be nimble and more flickable, while bigger S-Sizes deliver more stability and a roomier ride.
Sworks
TECHNICAL SPECIFICATIONS
COCKPIT
STEMDeity Copperhead, 35.0mm
HANDLEBARSSpecialized Trail, FACT Carbon, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm, 35mm
GRIPSDeity, Knuckleduster, Black
SADDLEBridge, 155/143mm, Hollow Ti-rails
SEATPOSTRockShox Reverb AXS, 30.9, 1X remote, (S1:100mm, S2: 125mm, S3: 150mm, S4-S6: 170mm)
BRAKES
FRONT BRAKEMagura MT7 with custom Loic lever blade, 203mm rotor
REAR BRAKEMagura MT7 with custom Loic lever blade, 203mm rotor
DRIVETRAIN
REAR DERAILLEURSRAM XX1 Eagle AXS
CASSETTESram XG-1299, 12-Speed, 10-52t
SHIFT LEVERSSRAM Eagle AXS Rocker Paddle
CHAINSRAM XX1 Eagle, 12-speed
CRANKSETPraxis Carbon M30, custom offset, 160mm
CHAINRINGSSRAM X-Sync Eagle, 104 BCD, 32T, steel
WHEELS
INNER TUBESStandard, Presta Valve
FRONT WHEELTraverse SL 29
REAR WHEELTraverse SL 27.5
FRONT TIREButcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.6"
REAR TIREEliminator, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 27.5x2.6"
E-BIKE
MOTORSpecialized Turbo Full Power System 2.2 Motor
CHARGERCustom charger, 42V4A w/ Rosenberger plug
UI/REMOTESpecialized MasterMind TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
BATTERYSpecialized M3-700, Integrated battery, 700Wh
WIRING HARNESSCustom Specialized wiring harness
FRAMESET
FRAMEFACT 11m full carbon, 29" front wheel, 27.5" rear wheel, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel, geo adjust head tube, geo adjust horst pivot
FORKFOX FLOAT 38 Factory 29, Grip2 damper, 44mm offset, HSC, LSC, HSR, LSR, 110x15mm, 1.5" tapered steerer, 160mm travel, Kashima
SEAT BINDERAlloy, 38.6mm
SUSPENSION
REAR SHOCKFOX FLOAT X2 Factory, LSC, LSR, 2-position lever, 55x210mm, Kashima
Sworks frameset only
E-BIKE
FRAMESET
SUSPENSION
DRIVETRAIN
Pro
COCKPIT
SEATPOSTFOX Transfer, 30.9, S1: 100mm, S2: 125mm, S3: 150mm, S4/S5: 175mm, S6: 200mm
BRAKES
REAR BRAKESRAM Code RSC, 4-piston caliper, hydraulic disc, 200mm
FRONT BRAKESRAM Code RSC, 4-piston caliper, hydraulic disc, S1-S3: 200mm, S4-S6: 220mm
DRIVETRAIN
REAR DERAILLEURSram X01 Eagle, 12-speed
SHIFT LEVERSSRAM XO1 Eagle trigger, 12-speed, single click
CASSETTESRAM XG-1295 Eagle, 10-52t
CHAINSRAX X01 Eagle, 12-speed
WHEELS
FRONT WHEELTraverse Carbon 29
REAR WHEELTraverse Carbon 27.5
FRAMESET
E-BIKE
SUSPENSION
RickBullotta
1,868
1,594
Sworks
COCKPIT
BRAKES
DRIVETRAIN
WHEELS
E-BIKE
FRAMESET
SUSPENSION
Pro
COCKPIT
BRAKES
DRIVETRAIN
WHEELS
FRAMESET
E-BIKE
SUSPENSION
My guess with this spec would be a weight increase of a pound or so?
Maybe I'm slow, but I don't get it. "565 watts of power...". What does that mean? Peak power? Why do they reveal peak power all of a sudden?
Status
571K
