I thought about coil but I'm worried about bottoming out all the time on such a relatively linier frame, or having to use a too hard spring making coil a bit pointless. Are you using a shock with HBO or maybe a progressive shock? Don't you have problems bottoming out when the frame only have 20% average progression?
Update after covering q few k's.Picked up a 9.5 in matt black while they were $2k off but only had the opportunity to ride it a few times up and down the street before heading off on holidays. (Had a great time in Tasmania riding Derby, St Helens and Maydena as well as catching the Enduro World Cup) Have been busy since we returned with the following mods -
Stock wheels seem fine to me and prefer alloy for the trails I ride.
- Invisiframe frame and fork protection
- 160mm Zeb Ultimate (would have preferred a Lyrik but out of stock and Zeb was same price)
- Super Deluxe Ulitmate shock with 65mm stroke (no clearance issues for anyone who's wondering)
- Hope tech 4 E4 brakes with beefier rotors
- Swapped the Deore derailleur and shifter for SLX (Only because I had a set in the cupboard! Would ideally like AXS but the existing works just fine. Will reconsider when it's replacement time)
- Race Face fat grips
- DHR/Assegai combo.
warranty and hope for an upgrade. sell them as soon as you get them back if they don't.So 3rd ride and now have the infamous loose hub already <sigh>. Has anybody discovered root cause or is it a straight warranty job? New wheels is on the list but not this soon!
"E ready" is really aimed at full power heavy e-bikes and has a slightly more open compression tune. IMHO, on an EX-e you'll be fine with a non-E specific model.Has anyone got any opinions on the need for a fox 36 'E' ready shock vs the standard?
"e-ready" huh?Has anyone got any opinions on the need for a fox 36 'E' ready shock vs the standard?
Yeah I get full stroke, a bit too often actually, might look for something different in time.People with the 9.5 fuel exe - are you able to get full travel out of the shock?
with mine set at the correct sag (30%), I cant get anywhere near to using the full 60mm of stroke, I always have 8mm-10mm still showing. I've taken the air can apart and confirmed there are no volume spacers/tokens fitted.
A normal bike with 110kg rider is NOT going to be doing 25kph up hill through a rock garden. E-bike tunes have nothing to do with weight, they're about differing use cases."e-ready" huh?
Considering that all normal bikes parts are made with people between 50kg and 110kg in mind, I always though it was really funny how they managed to trick people into thinking they need special parts for a bike that is 6 kg heavier than a normal bike. Drivetrain is different though, but shocks forks and brakes are just a sales bullshit gimmick.
Maybe a 110kg man will not go full ham in a rock garden, but he still exerts more force on the equipment than a 50kg that does.A normal bike with 110kg rider is NOT going to be doing 25kph up hill through a rock garden. E-bike tunes have nothing to do with weight, they're about differing use cases.
There you go again, focusing on weight. I thought I spelt it out but apparently not. Here's what Fox have to sayMaybe a 110kg man will not go full ham in a rock garden, but he still exerts more force on the equipment than a 50kg that does.
But here are still a lot more than 6kg difference between 60 kg and 90kg which definitely falls square in to what the bike is made for and you will find riders of all skill levels in that bracket.
Anyway, if it's not the weight that makes the tune different in a shock/fork from analogue to ebike, then what is it?
I look forward to hear this.
Yes I did it already (and make only 27km from new), I lower sag to 25% to manage it.
I tried only on local trail - nothing really extreme. Never had tis issue in acoustic EX9,7 on same trail
Thanks both - thats interesting, I cant get anywhere near full travel on mine. I'm not especially light weight either (82kg).Yeah I get full stroke, a bit too often actually, might look for something different in time.
Stupid question but you have it unlocked of course? In which case, try some bigger features!Thanks both - thats interesting, I cant get anywhere near full travel on mine. I'm not especially light weight either (82kg).
I guess I just need to try harder
"FOX’s e-MTB Tuned forks feature the same chassis as our standard forks except with a custom damper and air spring tune for the slightly different ways in which e-MTBs are ridden as compared to standard MTBs. For example, e-MTBs allow riders to conquer technical rolling terrain with greater ease than is possible on a standard MTB. In order to utilize the assistance provided by the bike in this type of riding the rider must keep pedaling. It’s difficult to maintain traction while pedaling over rough terrain. Therefore, our e-MTB Tuned forks feature a custom compression tune that helps keep the wheels glued to the ground at all times, maintaining traction and forward momentum, and a more progressive air spring tune to make sure that even though the initial stroke is softer the end stroke ramps up to provide the right amount of support for those bigger hits. These may seem like subtle differences but optimizing to even the smallest degree is a trait we’ve learned the importance of over our many years of winning races – sometimes by the smallest of margins."
Well, clearly you know more about it than anyone else. Can't wait for your suspension designs to hit the the market.If you believe that salesbullshit I have a bridge to sell you.
not a silly question, but yep it is unlocked.Stupid question but you have it unlocked of course? In which case, try some bigger features!![]()
You don't need to have a suspension factory to know these basics.Well, clearly you know more about it than anyone else. Can't wait for your suspension designs to hit the the market.
OMG, did you even read it?? You can ride up some seriously steep shit on an e-bike that you wouldn't even attempt on a normal bike but to do that you need traction. A lighter damping tune results in increased traction from maintaining better contact irrespective of weight.You don't need to have a suspension factory to know these basics.
I'm willing to change my mind if you can come with a way to tune a fork especially for emtb that does not mainly just take weight into consideration. What parameters would you change and why?
So you think they put a lighter damper tune in the ebike forks and shocks? lol.OMG, did you even read it?? You can ride up some seriously steep shit on an e-bike that you wouldn't even attempt on a normal bike but to do that you need traction. A lighter damping tune results in increased traction from maintaining better contact irrespective of weight.
I can get full travel without any bigger problems.People with the 9.5 fuel exe - are you able to get full travel out of the shock?
So Fox are lying about the differences?So you think they put a lighter damper tune in the ebike forks and shocks? lol.
Not a whole lot if you have an appropriate amount of ramp which could be just tokens as you have already noted.What would this do to descending capabilities of the bike do you think?
You know they're the same price right?You can't fault Fox for wanting to sell "special" forks to suckers and call them special and tuned for that purpose.
Fox did not write it was al lighter damper tune in the text you provided. But yeah, you seem very naive and kind of sweet if you believe all marketing claims you are being told.So Fox are lying about the differences?
