Jatem
The right side main axle bearing on the TQ is a metal shielded 6806 bearing, which has no rubber seal to keep water out. The sprag clutches are sitting just behind this bearing, and won’t be in good shape if water gets in. I’ve seen that service centres are replacing this with a sealed 6806 bearing.
Has anyone opened up their TQ and replaced the R side bearing - if so, how far will I need to disassemble the motor? Any tips or service manual/photos?
