Yes.Can you use the blevo app . without facebook? And will it work with a 18 levo expert ?
Yes.
Sure.. why you need Facebook for the app? ?Can you use the blevo app . without facebook? And will it work with a 18 levo expert ?
Hi!Can someone please confirm that the latest BLEvo app can change the speed limit on 2019 levo fsr with the brose 2.1 mag motor?
I thought you had to link it with facebook.. I miss read that, My bad am way to adhdSure.. why you need Facebook for the app? ?
Dear sdi,Hi!
Blevo does NOT work at this moment with 2019 levo. App works fine, speed limit can not be changed.
Also my dealer had no success until yet.
Brose 2.1 mag
Turbo Levo FSR
500Wh
Blevo 3.0.0
Hardware: 3.1
Firmware: 0.3.1
Motor Firmware: 6.1.0
Dear sdi,
Do all other functions work (besides the speed adjustment) in the Blevo app with the 2.1 motor including the heart rate mode? I am very interested in the HR mode but I am still waiting for my new bike. I hope you are able to test the function. Enjoy your new bike!
Thanks!
Dear Specialized Maastricht,
I am sorry. HR can not be testet due to missing HR Gadgets.
Rest of Blevo works fine. Just the touch screen seems to be a litte bit sensible when using the percentage +/- buttons.
All other functions are working fine as far as i could test.
I am using an iphone 8 @ ios12
Greetings from Germany
And yes. All other functions are working as far i can say. Blevo is a great app with much more possibilities than the original mission control app.
I would invest again. Hoping Paolo will fix the speed issue...
If i could anything try/test please let me know.
Thanks for the report..Hi!
Brose 2.1 mag
Turbo Levo FSR
500Wh
Blevo 3.0.0
Hardware: 3.1
Firmware: 0.3.1
Many thanks for your great work!Thanks for the report..
I will check when I will get the bike..
I can also ads that the "cadence" is not identified because Specialized removed the standard Bluetooth service for cadence and I need to analyze the new protocol in detail..
no.. you cannot do via Software.. sorry..PaoloBLEvo
Is there anyway that the motor can be turned off from the handlebar remote with the blevo app.
Or is that not possible through programming.
Would be nice to have the option to turn off motor from remote when on the flat and doing big days out.
Regards
Nigel
Is it looking likely that BLEvo will eventually be able to lift the speed restriction or is it likely a no go? Currently have a 2019 bike in order but this may be a dealbreaker for me, might go with a 2018 bargain instead ?
Any news about the speed limit?no.. you cannot do via Software.. sorry..
What I can suggest you is to setup the Smart Power in Eco with minimum value to 1%. BLEvo will automatically reduce the assistance when you will do flat pieces of road without much power from your legs..
@PaoloBLEvo Hi. Can you estimate when (if at all) you will add calories burned to Bike Monitor - iPhone or android version?I will try to add the calories burned in the next release..
Sorry.. I forgot to add it.. I think in one week I will add..@PaoloBLEvo Hi. Can you estimate when (if at all) you will add calories burned to Bike Monitor - iPhone or android version?
The watches are not supported as heart rate monitor because they don't use standard protocol to send heart rate information..
Sorry but only Bluetooth 4.0.. ANT+ is not yet implemented@PaoloBLEvo: What kind of protocol do I need to look for? Is it bluetooth only, ANT+ or any other type? I´m using BLEvo with an old Android Phone as bike monitor, the only thing missing is the heart rate.
Not yet..Have the Blevo team looked in to making an app for Shimano? Should probably be a large market!
I've got a 2019 levo and I would love to lift the speed limits .Any insight on the subject would be greatI released the new version of BLEvo for iOS.. version 3.0.1.
Hese are the news:
- Added Spanish
- Added battery beep management
- Added Stealth Mode management (Levo 2019 only)
- Added voltage and battery current in the CSV
- Added in the statistics the kcal consumed
- Bugfix size button
Please update the App from Apple Store and let me know if you will find some issue.
Enjoy your ride
Hi Witte300, could you tell me if there are some translation error in the App in order to increase the quality of the software? Thanks.I would love to be able to set the language manually. Still have my app to german, ios is set to dutch. Have removed the app and reinstalled, still german. Somehow blevo app mix the languages.
Love the app btw
