• Warning!!
    UK Pedelec Law
    Worldwide Laws
STUnlocker (ex Shimano STEPS Unlocker) Android & Windows App for derestriction/market change and etc
vadII
810
583
Earth
battery cycles is always 0 :unsure:
Yes, for some combination of DU/SC firmwares it's not stored in a memory.
If you think that it's not correct - try to use E-tube on Windows, it can make bike report - and you'll see
b4rt
18
9
CH
total distance is also not the same as on the display:unsure:
app: 63km
display: 128km
edit: sometimes it shows the right total distance
Trail Doug
96
81
Wrexham
I have 4.6.1 and can easily swap between UK and US regions Albez. There are reset to default buttons on pretty much everything however whilst I can't access the speed limit adjust screen due to my firmware revision I suspect that they would be present there as well. Can anyone on the older firmware confirm this?
vadII
810
583
Earth
New feature in the latest release - presets. You can save your current bike's settings as presets and use them for quick access. Some default presets are available in the App: Anti-thief, Power Save, Max Power and etc. (thanks to @valium64 for idea and help).
Carver
Russia
Many thanks for the quick response, responsiveness and patience. I will write the result after the test drive.
johnnyartois
Uk
I haven't received a reply to my request for a licence through the app. Understandable I guess as the 1st June date for the free offer has nearly expired to forum members. I'm happy to pay for this if it works as is should, just to unlock to U.S. settings. Will keep watching this thread. Couple of questions please: 1. How much is the full licence? 2. I have a Merida 160 900e which has Di2, is this a complication in using this software?
maramouse
185
126
Genoa Italy
Hello everyone, I made a further downgrade to firmware 4.3.2, with pc and pce-1 interface and without any problem, I only had the foresight, before following step by step, the suggested procedure on the site stepunlocker, to uninstall and reinstall E-tube and then insert the downgrade patch, disconnect the pc from the network and then connect the bike.
Ted3
12
8
FI
Any chance for one free android license?
Will test it on my brother's emtb (E8000 motor & E7000 display), and will buy second license for my own EMTB (arriving next week) if it works!
Thank you!
vadII
810
583
Earth
I don't have any unanswered request in my email box. Are you sure that you sent any request?
vadII
810
583
Earth
Thank you!
App works fine on this config (I own the same config on my bike).
564K
