Santa Cruz Vala
prolix2
75
45
United States
How is the new gen5 motor compared with the previous gen4 from Bosch in terms of power and punch ? Obviously the same specs on paper but how does it actually feels in comparison
My large weighs 47.6 lbs with pedals.
Just for perspective, my rail 9.8 carbon weighs 56 pounds. My fuel EXE carbon weighs 46 pounds. I'm looking forward to the power of the rail at closer to the weight of the fuel EXE.
DNE87
50
87
I know there are many variables, but if any owners would be happy to share your weight and what range/elevation you're getting out of the Vala on a full 600wh I'd be very grateful, just so I can build an average of what to expect. I'm in 2 minds whether to wait for the inevitable Bullit update, or pull the trigger on a Vala now. Cheers
mtbrdan
51
66
Scotts Valley,CA
jbrown....Stock Schwalbe's and they are sweet. DNE87.... I'm 210 lbs and three rides in this is what I've got so far....First was a factory demo and I got 28 miles and 3500 feet mostly in tour with liberal amounts of turbo, I'm guessing I had 5% or so left. Second was the first ride on my bike and got 21 miles and 3100 feet mostly in turbo, less than 5% left. Last ride was after work quickie, 1 hour, 12 miles, 1500 feet all turbo and had 35% left. Unless you just want more travel I would not hesitate on the Vala based on my limited experience. Range extenders should be getting into owners hands in ther next month or so I'm told and I would not hold my breath for a larger battery in the Bullit.
mtbrdan
51
66
Scotts Valley,CA
Another ride in the books, mixed in some trail and God help me even some eco. 22 miles and 4k feet. I am coming off of an Orbea Rise H30 that I put 7000 miles on over the last three years. Most of that mileage was on some rather soft coil suspension ( that I love as I have bad arthritis in both wrists ), getting the same compliant feel has been a challenge but I am getting it more dialed. The Vala seems to be about 15-25% more efficient than the Rise and of course is doing it with a top end of 85nm ( for now ) as opposed to the Rise with its 65nm.
DNE87
50
87
@mtbrdan appreciate your replies man, thank you for the insight. Sounds like you’re having a blast.
i have some thinking to do 🤔
I am after more travel really, more so than the bigger battery but word on the grapevine is the bullit iteration will have the 800wh, for only 900grams or so heavier, it would be nice to have also. I think I will have to wait it out.
Currently on a 170/170 with 720wh, but if I could get more range and 2kg lighter, would be the perfect bike for me.
However, If anyone else wants to chime in with their ride logs would be great to hear some more. Cheers 🍻
mtbrdan
51
66
Scotts Valley,CA
Not on the grapevine I'm on.
Dax
1,812
2,218
FoD
any idea when when its released and what specs?
Rumour is vala style 4 bar, 170mm, Bosch gen 5 with big battery, coming spring 2025. Might be the long travel e-bike to buy?
mike172
163
102
Is that not basically a Bullet (whatever its called) then??!! Still think the Trek Slash + is the ebike for me until I look at the price.
Anyone over stroked the rear shock yet?
Lee Dove
341
357
Look earlier in the thread, someone has put a longer stoke shock in taking it to 162mm rear travel. Not really needed though.
DNE87
50
87
Says whom?
The design engineers that designed the kinematic and chose the shock size to make that work. Why put a bigger shock on a bike to add 10mm of travel and mess the kinematic up significantly and not just buy a bike with 160/170mm rear travel in the first place. It doesn’t need it, wait for the updated bullit if you want more travel
TheMirrorVision
37
39
I wonder if/when Cascade Components will make a link for the Vala to increase progression and travel like they've done for other 4-bar/Horst link bikes...
570K
