- Thread starter
- #31
And Fox Float X2, slightly different linkage setup, plusher suspension, slightly slacker HTA, etc. But visually very similar, yes.so,it's the same as a vala but with 10mm more fork travel and 20 mm more rear shock travel?
Even if the new battery tech makes it more efficient and you can add a range extender for less total wh, but similar range?I love my santa cruz bullit. It plows downhill like DH bike. It's also pretty bombproof. I have hucked it off drops that you wouldn't normally see an ebike on, and it hasn't broken yet.
If the rumors are true, and they are moving to a bosch system with a non-removable battery, that is a huge miss.
I use two 600wh batteries pretty much every time I ride. If I can't swap out the 600wh pack for a fresh battery, I won't be looking at the new bullit when it's time to pick a new ebike. :/
It's definitely a huge flop for a lot of buyers to limit your full power eMTB to 600wh.
I'm sure the bike will ride amazing, but 800wh should be an option like every other enduro eMTB out there.
Exactly. Go buy one of those.like every other enduro eMTB out there.
65mm stoke.How did you get the 163 at the rear?
I’ve just swapped the radials as they are terrible to DH casing conti’s (Argotal & Kryptotal) and with pedals is bang on 23kg or for our friends across the pond, 50.706lbs.How much does this weigh?
No but I’ll get one tomorrow for you if you like.Do you have a picture from the side please?
In agreement with this!!!
The range extender is 250wh, so that is 850wh total I could potentially use for a ride. For the rides I do on the weekends, this is not enough capacity. I also prefer not to have 850wh of battery on board, it's too heavy and you lose the ability to carry a water bottle.Even if the new battery tech makes it more efficient and you can add a range extender for less total wh, but similar range?
Aside from the dropper insertion.Crestline is doing it right.
Agree with you here. The biggest day I've done so far was ~32.2 miles/51.8km with almost 6,800 ft/2,072m of climbing on a Trek Rail with 750Wh battery and I had ~13% battery left as a ~250lb rider. The Bosch 750Wh battery is actually only 723.6Wh (36V * 20.1 Ah) so the new 600Wh being ~17% lower capacity should cover 99% of my riding, and a PowerMore range extender should help with the other 1%.Aside from the dropper insertion.I love what Crestline is doing, except for that. I'll use that extra 30mm of drop way more than I'll use the interchangeable battery.
Nah 600 is perfect, I’m glad they didn’t cater to the small percentage of people that only exist on the internet who use more than 600 on the daily. For those that need more go buy an ugly bike.
6’4 x 240lbs. My Bosch 4th gen 750 only gets about 5,000’ of steep vert before it’s drained which is just under 2hrs of riding. I sure AF don’t need less. If the new bullit is actually 600 Crestline has out-Santa Cruzed Santa Cruz two times in a row.Agree with you here. The biggest day I've done so far was ~32.2 miles/51.8km with almost 6,800 ft/2,072m of climbing on a Trek Rail with 750Wh battery and I had ~13% battery left as a ~250lb rider. The Bosch 750Wh battery is actually only 723.6Wh (36V * 20.1 Ah) so the new 600Wh being ~17% lower capacity should cover 99% of my riding, and a PowerMore range extender should help with the other 1%.
Highly doubt this. They wouldn’t have a full powered ebike in their lineup. That would be a dumb move.600w
Tell us you’re small without telling us you’re small.
On point. Also from the view of supply chain it wouldn‘t make sense to have a different option.The main reason for brands only offering 600w is wanting to have a lighter and slimmer looking bike as Bosch's 800w battery is very big/fat.
The Bullit share the same frame in general with the Valla and will be 600w only as well (100%).
Expecting SC to change a mold just because the bike has more travel is unfortunately unrealistic,especially with the state of the bike industry.
I wonder if anyone has measured the DJI Avinox 800Wh battery next to the Bosch 800Wh one, as DJI’s looks considerably slimmer but may be longer? Or it could just be smaller in every dimension as the Amflow bike doesn’t have a pregnant looking downtube with all that capacity.The main reason for brands only offering 600w is wanting to have a lighter and slimmer looking bike as Bosch's 800w battery is very big/fat.
Would be crazy to have a long travel bike with a small battery. The reason for getting long travel is because you're going to be shuttling more Enduro/DH trails, so you want full power large battery.
That might be your reason but not necessarily everyone's.Would be crazy to have a long travel bike with a small battery. The reason for getting long travel is because you're going to be shuttling more Enduro/DH trails, so you want full power large battery.
I do and that is what my old bike had, it was never an issue. Some people just like to worry about every little thing and to them I say go buy an ugly bike.
