Funny you should say that because I updated the firmware on Sunday and it took ages , seemed to stop , said it lost connection then reconnected and continued by itself. I'd not even looked at error codes at that time , noticed that yesterday
That's exactly what mine said , was unstable connection so I moved the bike closer to the house and it continuedKept saying the wifi was unstable and and failed acouple of times so I sacked it off and brought the bike in the house to try again which is when my problems started
Have you also done the firmware update ? Wondering if it's anything to do with thatJust checked mine only done 35 miles on it abs have the same error code too !!! View attachment 57812
I had no issues with the firmware update, but I use the Windows based software and the SM-PCE02 USB -> eTube adapter.
Did you have this error logged as well ?
This where I could've messed it up. Think I disconnected or turned the bike off midway through before bringing it in to the hose to try again. It's now just stuck on a constant loop of the above screenshots
From the FAQs here, I think you'll need to have your LBS restore the firmware using one of the cables
It hadn't , no , but I'll check again when I get in from workHas the error now gone Steve ?
If it can log an error if cranks move as it's switched on its highly likely that's what's happened , especially given the position of the on off switch
