Reign E+ 2022
turborrojo
7
7
Galicia
Hi all
Do you think a M or a S size will be more suited for 1,70m tall rider? I’ve tried a M in a shop and seemed to be OK and comfortable for me, but due to the steep seat tube and long chainstays, I’m a bit unsure if it will be too long in the trails.
thanks
zorro77
320
486
Italy
Hi all
thanks
Size M (y)
Rob Rides EMTB
Administrator
Staff member
6,298
13,883
Surrey, UK
Uploading
Donamici
139
171
Ireland
It was only long for those of us with our fingers hovering on the button! But as you said, Christmas and poor weather probably slowed down this video's delivery. As your channel grows though sometimes it's better not to let 'great' be the enemy of 'good', especially with a content hungry audience. 🙂
mummyb0t
23
10
New Zealand
I've not installed the app yet as I've been wary of all the problems people have had, so quick question...is power mode set to full as default?
I havn't had any problem with the app lately, I did early on (playing with LED brightness setting broke the bike for 48hrs), but now I use it regularly to check exact charge levels when i don't have my garmin connected. its seems fine, I mean kinda crap, but fine.
goroncy
274
345
Munich
Did you try to change the LED brightness? Or update the bike's firmware? I'm still petrified to do it after 2 times the bike was out for more than 24h :(.
Banksay
49
66
Arbroath, Scotland
Connected the app and nothing seemed to self destruct ;)
How do you check the firmware? Does it just automatically prompt you if newer software is available rather than an option to manually check for updates?
mummyb0t
23
10
New Zealand
yeah it prompts you, from memory, it won't let you continue to use the app until you complete the update.
Implor
168
83
Sweden
Great review Rob!
Would have loved to hear some battery range comparison to likes of Bosch Gen4 with same battery capacity (for example Trek Rail).
its most likely a pain to do correctly. Same tires, same pressure, similar suspension setup and so on.
To do good you would need to put it on a trainer. A rig to spin the pedals and see how long it last in different modes.
Torque is proportional to current. So if you have a low rpm with max torque it will most likely drain you battery quicker but you may have a much more pleasant motor to use.
maurocif
29
34
Rome
Thank you Rob, excellent review as usual!
I'm using a 2022 Reign+ 2 since last December and you confirmed every my feelings and opinion about this dream bike! Unfortunately my poor English didn't allow me to understand you when talking about the possibility to replace the 625 Wh battery with the more capable 750 Wh model: is this possibile? I'm addicted with high level assistances, so this replacement could improve the range of my rides.
Thank you again!
goroncy
274
345
Munich
Thank you again!
It's possible. You can change to 750Wh battery.
577K
