MrSimmo
Build Vid if anyone is interested
Wow, love it
Fair play mate, looks stunning
It certainly is awesome. But my dream build spec would be quite different to this!....Absolutely stunning. Don't think you could get a better build!
I can't wait for a ride report
Pedals and a coil shock and this thing is knocking on the door of 26kg.
No, the frame comes assembled, motor and swingarm installed.Nice vid. Does this mean framesets will ship like this - the user will have to assemble the swing arm, install the motor, etc?
If so, I might need to do some tool shopping.
Frame with links and shock 5-5.2kg?? Heavy but not horrible i guess. Half a kilo heavier than heavy ass endure frames like older gt force or commencal meta amVoima ID Frame Weight, K2. With battery lock and mount. No shock linkage.
Weight: 4310g
Totally.. As long as you can ride a 26k bike of coursePedals and a coil shock and this thing is knocking on the door of 26kg.
Beautiful bike no matter what the scale says though.
Nice ^^Build Vid if anyone is interested
Looking GOOD.Bike pron
View attachment 110984 View attachment 110985 View attachment 110986 View attachment 110987 View attachment 110988 View attachment 110989 View attachment 110990 View attachment 110991 View attachment 110992 View attachment 110993 View attachment 110994 View attachment 110995 View attachment 110996 View attachment 110997
I am also keen to understand what X2 and not E-Storia. More testing? or is x2 your preference?@Rob Rides EMTB What happened to e-storia, is it on demo Voima?
I chatted with EXT folks in Sedona this March, and they strongly suggested going with e-storia over arma for Voima. Not because of steel shaft, because oil volumes and adjustment range on storia are larger.
And they said that ext long travel fork is not really there yet, but will be sometime later.
EXT arma v2 on my Pole Machine is best shock I ever had, it worked so well from the factory with custom bike/weight/style tune that I never touched any settings. Probably just adjusted rebound once while above 2500m alt mark due to major temperature drop.
While CCDB Kitsuma on mine feels nice and can be tuned, nothing beats personal custom shimstack tune from pros.
When the EXT Era LT is out I’ll probably swap ZEB to it, and probably shock as well.
Say what you want but the Wild is light weight depending on the configuration. Rob himself weighed one in a 20.81kg with a 625wh battery and race motor even on Assegai tires and no pedals. It's right in his video.People for this type of bike it is not heavy at all.
Just watched a video with the new so called light Orbea wild.
But it’s still not a Voima.Say what you want but the Wild is light weight depending on the configuration. Rob himself weighed one in a 20.81kg with a 625wh battery and race motor even on Assegai tires and no pedals. It's right in his video.
The one he was testing came in at 22.9kg for an XL, with the 750wh battery and double down casing Assegai tires. I'd say that's pretty good.
But it’s still not a Voima.![]()
My 22 heckler is built like a tank. 21kh with 504 an battery and close to 22 with 720wh.Say what you want but the Wild is light weight depending on the configuration. Rob himself weighed one in a 20.81kg with a 625wh battery and race motor even on Assegai tires and no pedals. It's right in his video.
OK, i've read through the thread and i'm going to continue riding analogue. The cramped cockpit, due to the too steep SA, is a no for me and the sticking plaster solutions of ramming your seat back or using an adapter will only add premature wear to the dropper. It's also increasing the potential for knee problems, as the SA will see a lot of riders with their knee position way in front of their pedal axles, which is ergonomically all wrong.
Lastly, the cracks and seam splitting really concern me.
Cracks and seam splitting.. I missed that. Was this covered in this thread?OK, i've read through the thread and i'm going to continue riding analogue. The cramped cockpit, due to the too steep SA, is a no for me and the sticking plaster solutions of ramming your seat back or using an adapter will only add premature wear to the dropper. It's also increasing the potential for knee problems, as the SA will see a lot of riders with their knee position way in front of their pedal axles, which is ergonomically all wrong.
Yes. I have both bikes (Kenevo 29er).Has @Rob Rides EMTB or anyone compared the Voima 190mm with a Kenevo/29er custom build? - I.e. which way would you go? - Voima 190mm or the 29er Kenevo build?
Thanks Rob, sounds great.Yes. I have both bikes (Kenevo 29er).
I wanted the Kenevo performance with the Bosch motor and 750 battery. What I got with the Pole is that and more - the Pole climbs better and has a very similar feeling to ride, but the rear suspension is a little bit more progressive for the biggest of compressions. Also, with SRAM Transmission, I can run it on Voima, the Kenevo is too old school (Non UDH). Transmission works crazy good, I don't think I ever want to go back to anything else.
From the way it rides, to the build quality, everything is very very good.
The 2023 Voima, in the setup I have it in, is the best bike I've ever ridden (IMO, of course).
I think you are missing my point. K1 size dimensions are all perfect for me except TT. TT is uncomfortably short. K2 TT is perfect for my size, that is also not too stretched for seated pedaling. Its just right. But the rest of the dimensions of K2 are too long for my liking. Wheel base too long, reach too long, front center too long....
That's why I haven't hit go yet. I dont want K2 sizing at all other than TT dimension so that size is out. Its wrong for my riding style. K1, I might suffer extended sore back for having a TT too short.
I would if i could land one into nz for less than $18k. But min cost into nz is $22k, and that's for a spec I dont want. If i then bought and sold parts to get to my spec if would cost $26k. Thats just crazy time.Maybe consider a Crestline? Similar travel at 180/175mm but a little closer to the geo you’re looking for and a similar price.
RS 75/50 EEB – SOLD OUT – Crestline Bikes
crestlinebikes.com
Is there plenty of long travel e bikes out there? I can't find many at all above 170mm rear end.I have a cost effective solution: don’t buy one.
Seriously, Pole are going for a niche market and some people are, almost by design, not going to get along with the design. That’s fine. There’s plenty of other bikes out there.
Here's one for the moderators, would it be an idea to split this thread and have a separate thread for sizing?
There doesn't seem to be much riding of the bike and observations how it handlers on trail etc, it's all size related.
Just an idea, don't shoot me![]()
