Levo SL Gen 1 Official Levo SL Thread
shakeystart
48
16
1617daY
go with a sram eagle 32
True to Specialized bastardizing componetry, there are very few choices for chainrings. It looks like there is no option for direct mount, which is my favorite, and only a couple of choices for the 94BCD 32 & 34 tooth rings. What exactly are you guys using?
boBE
415
363
FL
My motor has 42.6.1c (US spec) but I did not notice any difference from before the update.
LS1Steve
7
11
SF Bay Area
Whats everyone doing to protect their drivetrain after a quick spray-down? After only my second ride, I rinsed off some dust, and after everything dried, I was very surprised to see my NX chain ring, chain, and cassette with some slight rust ALREADY! WD40 fine? Teflon spray?Trying to figure out the best way without overspraying and making a mess on the otherwise cleaned bike.
SquireRides
540
557
WD40 PTFE spray. It's all I use in summer as a super 'dry' lube. A blast of that shifts the water, knocks off a lot of the dirt and grease, and lubes nicely.
SL-ED
37
47
Bay Area
These are real ones, If they’re the same like this:
Wouldn’t be surprised if China has already copied it tho. Seems amazon is the prime place for China to offload their copies for high prices.
Thanks BAMBAMODA
onkelshort
26
26
Upgrades: Fox 36 160mm and CC IL Coil with 210x52.5mm Onza tires and Newmen carbon bar and stem. Perfect bike, great DH performance with tunable coil shock and still arround 18,4kg.
When the NX is worn down I'll upgrade to GX and safe some weight to get <18kg.
Tobers
140
309
England
I dry off the bike with a cloth, then use GT85 spray on anything that moves and isn't brake related. I wipe off the excess. Then some Finish Line dry lube for the chain.
Lightme
239
256
Sydney
My own SL build ... I´m a long time bike fan, weightweenie and a dream bike builder.
MORE PICTURES AND WEIGHT: SL 15.47KG
That is light! My comp Carbon SL build (XL) with carbon bar, front and rear sus upgrades, GX drivetrain comes in at 19.1kg!
My pedals do weigh 430g. My spec is below, keen for advice on how to shed some weight! Not too concerned, still an amazing ride, just beefier than expected.
Manitunc
107
75
Florida
The. Wheelset on the. Carbon comp is very heavy. Light carbon wheels and lighter tires are a must if you want to get in the 16kg area.
Setter
19
52
Sweden
my engine has given up on my levo SL. It started with the engine sound changed after about 500km. Then the crank was not disengaged from the engine so the pedals cranked by a quarter of a turn when you stopped pedaling. Now the crank goes around but does not pull the chain with it ... Has claimed a warranty in June and still has not had the error fixed. Anyone else with similar problems?
p3eps
1,984
2,406
How did you fit a 34T on the SL? I tried a 34T but it hits the chainstay on my 2020 SL. Looks like a 32T is as large as I can go with the stock setup.
You need an offset 34T chain ring. Plenty of people have 34T on, and the manual says the biggest you can go is 34T.
shakeystart
48
16
1617daY
When you say offset, you mean a 3 or 6 mm, as in boost, etc.? Could you link to the proper ring? Of course that would effect the chainline, but maybe that doesn't matter?
Mr E
Uk
Can anyone with a better understanding of suspension help out-
I want to upgrade the rear shock on my SL and I’ve found a dpx2 210 - 55 second hand. The shock is off a bike with 140 rear travel so I guess the suspension leverage is different. So the question is, will the dpx2 work correctly on an SL or will it need altering/ tuning.
Manitunc
107
75
Florida
Yes, it will work fine. You will have to adjust air pressure for your weight and riding style. You can add tokens if you need more progressive damping.
boBE
415
363
FL
Thank you, this was the exact 34T chainring I tried, but these are flat (no offset), and there was interference with the chainstay.
Odd, this is the chainring I installed and from the shadows we can see there is clearance.
Mr E
Uk
Thanks, Yeah I can do that stuff but it was the custom tune that fox do for OEM frames i.e degressive/linear/ soft- firm tune etc. depending on how the OEM rear sus is working. I’m not sure whether it makes much diffence, or whether it can be manually tuned out using the user adjustment settings.
567K
