LightCarbon LCE971, VPP/DW, Bafang M510/M600/M560
Bluicie
14
24
Belgium
Good looking bike, giving some Santa Cruz and Specialized vibes.
One of the responses to the Facebook post about this new frame mentions a price:
clix
179
201
EU
It is a bit confusing. M510 is probably correct. It has very similar geometry to LCE930. Front triangle has basically the same geo, but rear center is a bit longer. It is interesting, that they went with some kind of VPP/DW link (whatever you call it) design. I believe that is the first one for ligthcarbon? Looks good.
Cca 1kg heavier frame than LCE930. I hope that LCE930 is strong enough for proper riding, with that 1kg weight saving. 😃
brbr
467
250
France
The pivot mechanism might be heavier than the "simple" design of the LCE930, let's hope our LCE930 won't break on the first jump :D
JimLee-Lightcarbon
Lightcarbon
Apr 15, 2022
273
306
Amoy
Now only size M past the test, loading time more than 30 days, size L is still on test,
the frames is heavier because the special design for rer shock, just as same as brbr said,
no need warry about the quality of LCE930, even is lighter than LCE971, If we can sell it publicly, it means that this frame has passed strict tests. Many people have received our LCE930 frames and can see how perfect our frames are inside,
JimLee-Lightcarbon
Lightcarbon
Apr 15, 2022
273
306
Amoy
Some
Hi Jim Lee,
i have just received the frame today, we notice this on the frame, what is the purpose of it? View attachment 127035 View attachment 127036
Overall carbon finish is more refine compared to the E10
Sorry for not replying in time!
That bolt is used to secure the fender. I have already explained it to your purchasing agent, Alice from fieldebikes.
Many of our processing technologies are leading in the country, such as CNC processing at the BB position. Currently, there are only the OEM supplier of Specialized bike and our factories in China.
streyer
17
24
Singapore
Hi Jim,
Can i fit the original E10 battery in this frame? Also, Do you have it on size small?
Thanks,
Caio
E10 is unable to fit as the battery case size and connection end points are different. With some tools and add ons, you can get it to fit.
JimLee-Lightcarbon
Lightcarbon
Apr 15, 2022
273
306
Amoy
Hi Jim,
Thanks,
Caio
the battery box are different, so I think it can not fit for it, we can supply the empty battery box if you want,
now only size M and L, size S maybe in future!
526K
