Any idea of the release price of the comp carbon? Debating getting one. Have the Gen 3 now.That is the comp carbon
You made my day. Thanks for sharing this
Not many hours left until the spec and price will be published and then reviews will come, so then the discussion about which reviewer is best![]()
and which one is the most truthful........Looking forward to the reviews about just how fast this bike is. But failing to mention which power mode its in...Not many hours left until the spec and price will be published and then reviews will come, so then the discussion about which reviewer is best![]()
This is an incredibly terrible idea. If I were in charge of trails access I would just ban this gen Levo, because it's effectively a class 3. It's like allowing a class 3 if people promise to go slow.
Submitted questions to my LBS where I bought my comp carbon this past Nov 1 (owned my rise for just over 5 months) asking about specs so I can decide (am I really just getting more torque & higher wh battery?) Whether to sell my Gen 3 to buy a Gen 4.Not many hours left until the spec and price will be published and then reviews will come, so then the discussion about which reviewer is best![]()
Think the issue is more with the larger fat tire ebikes that weigh 75-100 lbs. The extra weight of those will chew up the trails. Trail builders work hard to create these trails, and they take a fair bit of maintenance, too.Respectfully, I've never understood the logic of not allowing a class 3 on trails if the only distinction between it an a class 1 is the maximum speed it will go. I completely understand and agree with not allowing motorized bikes with throttles on trails.
Not allowing a class 3 mountain bike on a trail because it is capable of going faster than 20mph is the same logic as not allowing a car to drive on a road that can go faster than the posted speed limit.
If your concern is people promising to go slow and not following rules, highly experienced analog riders often go much faster downhill and any e-bike rider can also go faster than the pedal assist limit when doing downhill. When I'm on paved roads going downhill, my bike often goes into the mid 30s.
I bought a Bulls Iconic specifically because it's a class 3 because the majority of my use is riding locally along the coast from my home. It's at least 1 hour round trip for me to drive to any trails. When I do ride on trails, I never go over 20mph and most of the time, much less than that.
If the concern is a bike that can go faster than the posted limit, I live in California and every time I see a posted speed limit on a trail, it is 15mph, so with this thinking, perhaps class 1 bikes shouldn't be allowed on these same trails either.
Agree (in addition to throttle bikes). If a class 3 ebike has the same tires and weight as class 1, there should be no concern. As mentioned, it the only concern is potential speed, analog bikes can go much faster downhill if a rider chooses to.Think the issue is more with the larger fat tire ebikes that weigh 75-100 lbs. The extra weight of those will chew up the trails. Trail builders work hard to create these trails, and they take a fair bit of maintenance, too.
When most people think Class 3, I think they're referring to heavier bikes which are less maneuverable & can cause greater injury on a trail (blind corners, rock gardens, downhills, etc).
For the money, the Copperhead EVO AM3 might be the best deal out there with a 750wh battery and $3,600 US.Doug, those Bulls' are really nice bikes.Rode the Copperhead Evo AM3 & lived it.
Do you mean "only one" Sensor?why does the 2026 levo only have a sensor pick-up on the rear wheel? ...
This is definetly not pink
I am starting to like the display .
Thank you for posting. Is the pro black or a dark grey?
Any shade of pink, not for me...
I reached out to Bulls asking about the Vuca emtb (pinion mgu w/ Gates belt drive, available in Europe), and they said it will be available in the USA once they have a support network for it.For the money, the Copperhead EVO AM3 might be the best deal out there with a 750wh battery and $3,600 US.
Said this before its Champagne and not Pink.. learn colors..That's terrible, do you know the color of comp carbon?
340 was a typo, and wanted to post the allen fastener release as ppl asked about security of battery340 was a typo right?
340 was a typo right? If an Allen is used they are probably using some system like Giant has.
I must say the system is pretty solid, keeps the battery secure in all conditions, the downside is that it adds cca 500g of extra weight(that is where the weight of the new levo comes from). Some Giant users modified theirs with 3D printed parts and saved up to 400g with that.
Well the alloys coming with the 600Wh imo is a marketing strategy, offsetting the heavier alloy bike with a lighter battery pack.
I am interested into the internals of the new Spesh(Brose) motor, as a lot are saying all metal gears and all.
I am following the development of the Brose Drive³ Peak and so far I haven't seen an open motor with the guts on display. I don't doubt that it's all gears inside as Brose says, but I am interested if they use all metal, a mix and if the gears are straight cut or helical or a mix. If someone has pictures or more info please enlighten me.
The Motor is all metal... I have seen the expanded drawings for it and its the move ppl were looking for as there is no belt anymore. They are wormed gears. As for pics let just say I cant share, but it will be on Specialized site on Tues for all to see.340 was a typo right?
Then your LBS has some deal, as I have a S-Works and it only comes with the 840. the other two are separate purchasesAgain, I was told S-Works gets all batteries and fast charger with your order . . .
Wormed gears have a very low efficiency, not suitable to use them in a ebike motor...The Motor is all metal... I have seen the expanded drawings for it and its the move ppl were looking for as there is no belt anymore. They are wormed gears. As for pics let just say I cant share, but it will be on Specialized site on Tues for all to see.
