I'm thinking of making some charts to help people find the relevant info when looking to make a new bike purchase.
the charts I'm thinking of are
there are probably more that would be useful to. so if you think of something please let me know.
Now if you could give me the info of your bike, what make and model it is.
Whether its battery is
Don't know what the correct terms are for some of the above so if you could point me in the right direction there that would help, thanks.
Weight
How heavy is your bike and what size it is. Ideally this would be its stock weight without any mods. if you have changed components please let me know.
If like the focus it can have a separate battery add on can you list it with both weights one without the battery and one with the battery added please.
Motor
Which motor system does your bike use.
Suspension
travel back/front (example 150/160) in mm please
system used (example horst link, dw or single pivot)
Intended use Trail , Enduro or DH (dont know how were gonna clarify this one)
if there are more subjects you think it would be helpful to have a chart for please let me know.
As each subject gets added or refined I will update this post.
- battery mounting - how easy is it to swap
- weight
- motor type
- suspension
- internal fixed (can't be removed)
- integrated (internal but removable)
- integrated but using a external battery (external battery fits inside the frame)
- external.
- capacity (if the bike can take two battery's like the focus please list the capacity for the main battery then the capacity for the add on pack.
Weight
Motor
Suspension
